AH FabricationsSky Insurance
Results 1 to 14 of 14
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Finally found an S3!
    So i have been searching high and low looking on every car classifieds going for about 2 months with no joy
    Now i've finally found exactly what i'm looking for!
    Imola Yellow facelift 210 S3. I wanted the 210 as its considerably cheaper to insure over the 225. And i plan on doing a bit on tinkering and i understand once re-mapped they both come out with the same power figures
    I wanted something mint with fair mileage (70-80k) in totally standard form with full black leather and as many extras as possible. Also had to have FSH with the big cambelt/water pump service already carried out.
    I was starting to give up hope as i was dead set on Imola Yellow then a few days ago one came up.
    So i'm off travelling up the country on Friday to view it with the intentions of buying!
    Any tips/advice as to what to look out for? its just had a fresh MOT and just had a full HPI check but are there any obvious or common flaws/faults i should look out for?
    Thanks in advance!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    Loads,where to start ? roof rails and bumper strips corrosion
    Dansmith's Avatar
    Apr 2009
    Bournemouth, United Kingdom
    460
    other than the normal check for rust along the roof rales! can be fixed under warranty if it hasn't been fixed before! Other than that! enjoy
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    By bumper strips do you mean the door and quarter panel trims? Is that a primary spot for rust then?
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Yeah i here they have a 12year manufacturers corrosion warranty
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,868
    rusty linky....12 year mmm it depends
    http://www.audi-sport.net/vb/showthr...EASE-POST-HERE
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    724
    double check service history with whoever stamped the book.
    Anyway, surely after tinkering and mapping to bring it up to a similar 225 engine power the insurance will be a lot higher than just insuring a 225 in the first place ?
    Also I have to add if the difference in insurance costs between the 2 worry you than I would think carefully if you will be able to afford to run one ! Albeit I understand you are trying to minimize this by buying one with the cam belt already done.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Another area prone for rusting is the trim where the boot lock is. Dead pixels in the DIS are also quite annoying but dont think it'd put me off buying one if it was a nice example, just turn off the DIS.
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Sorry dude what is the DIS? Thanks
    wibble111's Avatar
    Nov 2006
    derbyshire
    829
    Its the driver information system (i think anyway) in the centre of the clocks, shows you avg miles, temp, radio/cd info etc. Mine in my old A3 was shagged and really used to p**s me right off, i didnt know it because it was switched off when i bought it, when i eventually learnt how to switch it on it was shagged and i was mighty upset lol.
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Check the service history even if it means phoning up the dealers who have stamped it. Check the xenon lights are working and not pointing to the ground, have a look at the springs (around the bases) to check there not snapped. If you can jack the car up check the collers (butts up against the bush) on the ARB's these are prone to breaking off. Check the inside face of the discs, check for uneven tire wear.
    fran-s3's Avatar
    1,090
    make sure when you take it for a test run...
    a) no rattles front the front or back (usually suggests arbs or bushes) if so haggle... least 250 if it's the arb to buy and replace at a garage
    b) it goes to 90degs on the water temp and stays their - another common problem mine wouldn't settle when I first bought it... was thermostat I had no idea at the time thought it was normal! Again 100 to sort prob at a garage buy and replace
    c) check the washer motors work esp the rear... My pipe split, common problem easy to replace but again you can haggle
    d) check rust on the lock panel on the boot - common place to rust again common problem mine had rusted... haggle if you can
    e) as mention the dis....
    f) check everything electrical like the seats which are electric check they both higher lower, forward back a and lumbar... press every button in the dash, sunroof, heated seats, parking sensors if any just make sure everthing works... Check all headlights....
    g) check the seat mechanisms... my rear passenger seat when you push lift lever to go to back tilts but doesn't slide!!! common problem I didn't spot when bought and it's annoying me so much... again haggle if you do...
    Hope this all helps....
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Full service history oil\filter, Haldex oil\filter, brake fluid
    Cam belt/Water pump 60,000 miles or 5 years
    Essential Checks
    1) Rust on roof rails
    2) Stereo volume problem (can't be fixed, you need to replace stereo)
    3) Window clip problem
    4) Rear wiper
    6) Oil Use (Look for signs of an oil leak, look at exhaust fumes, it could be the Turbo letting oil past the seals)
    7) Electrics on seats check
    Start the car with a cold engine – watch out for delays, starting problems and excessive smoke and excessive noise, Look out for blue smoke, which may indicate an internal oil leak Temperature gauge should sit around the halfway mark, Watch for signs of oil leaks, particularly under and around the top of the engine, Check the oil level is correct – remove the dipstick, wipe with a cloth and replace for a couple of seconds. It should rest between the min and max marks, oil filler cap for a white mayonnaise-like substance – this could indicate a damaged head gasket, Check all switches work – including heaters and air-con, Check the exhaust for excessive noise before driving, Turn the steering wheel from one lock to the other before driving – there should be no screeching, banging or knocking, Test the handbrake by pulling it on and trying to drive off gently, Use all the gears, including reverse, Brake sharply – the car shouldn’t pull to one side, Make sure the car’s mileage tallies with MOT certificates and service history
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Jul 2008
    25
    Listen for rattle/grinding noise on startup, and a rattle from engine at around 1800 rpm in lower gears. Possible oil starvation to top of the engine.
