Chris NottBadger5
    Mar 2010
    UK, SOUTH
    19
    S3 question...any ideas?
    got an x reg S3 and wen engine is turned off you hear a sound from engine, been told its like a turbo timer that keeps pumping the oil round for a few mins..but recently noticed its not doing it anymore? is this a bad thing??? any ideas?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,462
    Its the after run pump and it pumps water not oil my friend...
    It not working is an issue tbh... Its not an uncommon problem and from what I have read it can be anything from a fuse to replacing the pump (obvious really and not much help... soz)
    Start with the obvious, fuse and work back from there.. Not sure if its one of the fuses on top of the battery or one in the cars fuse box..
    <tuffty/>
    Mar 2010
    UK, SOUTH
    19
    ahh cheers mate, will check the fuse then go from there!
    Ross_S4
    Aug 2009
    Dundee
    718
    I think it is fuse 16.
    Mar 2010
    UK, SOUTH
    19
    checked fuse and its fine, had a read up on the after run pump, apparently only kick in if temp reaches 110 c. so will have to do a few experiments to see if it is broken.
