Volks AutosEM Tuning
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Drivers side window movement/noise? Poss weather related!
    Over the weekend I noticed the drivers side window makes a slight noise when going over a bump in the road, rather like the final "zuuumpp" noise as it settles into the rubber seals after going up again. When I push against it, there is no movement (that I can detect).
    However, yesterday evening in the cold again, after an relatively warm weekend, it had stopped. It must be something that is affected by hot and cold weather and I have heard chatter about plastic clips failing, that hold the window to the rails?
    Anyone shed any light on this?
    Many thanks,
    James
    Sanj's Avatar
    Blue Beast
    Nov 2008
    174
    I actually have the same problem which i was going to post on here, its quite annoying......
    Would be interested in what causes it......
    Current: Nogi Blue S3 BAM ⁞ Andy Mac sub ⁞ Forge 007P ⁞ TT Pedals ⁞ LCR Splitter ⁞ EBC Discs ⁞ Greenstuff Pads ⁞ Forge Short shifter ⁞ Spacers ⁞ Badger 5 TIP ⁞ Jetex Cone Filter ⁞ RTech Stage 1 Remap ⁞ 8P Gear Knob ⁞ N249 Delete ⁞ Oil Catch Can Mod
    Previous: MK3 Golf GTi 16v
    JD09's Avatar
    Dec 2009
    3,080
    OK so this has stopped lol!
