JMB RetrofitsVolks Autos
Results 1 to 9 of 9
    turbo nut
    leeds
    esp not working s3 bam engine code
    ESP light comes on and stays on when the ABS does a system check at 10mph.
    When I scanned the ecu it come back with 01324 abs fault code.I have cleaned the wheel speed sensors as they are apparently prone to getting dirty but that did not cure it .Does any one know of this fault as i dont want to take it to the dealers and get ripped off lol.
    any help would be appreciated
    Last edited by Broken Byzan; 22nd March 2010 at 16:49. Reason: To make it readable ,as we do not charge by the letter.
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Help with your issues noted above, or help with your English?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    01324 fault code suggest there's an issue with your haldex. I'd disconnect the plug on the haldex module, give the plug a clean, reconnect, erase the fault code then go for a drive to see if it returns. If it does your module maybe faulty
    turbo nut
    leeds
    just want help with the fault but thanks anyway mate
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by turbos3 View Post
    The fault's with your haldex
    turbo nut
    leeds
    where is the haldex plug and is it easy to get to. many thanks
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    From what a remember bud it's pretty easy to see the plug, i think there's only one plug that connects to the haldex
    turbo nut
    leeds
    i will get under now and clean the plug and spray with wd40 . the 4x4 system does works fine with power goin to the back wheels but its worth a try. would have thought if the haldex is faulty i would lose drive to the back wheels ....? thanks mate
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Your haldex is probably fine bud, if the connection isn't 100% it might of got a little upset hence chucking that fault code up. Once you clean it make sure you erase the fault, then give it a go
