EM TuningMonster Motorsport
    May 2009
    123
    Bad Idle - no power when moving off in 1st and 2nd, random jumps in 3rd. please help
    Ive got a 1.6 A3
    ok so ive just had my clutch replaced and flywheel machined, also the abs light is usualy on, but it goes off at times.
    the problem ive been having is once the car is started for the first time that day, on colder days especially, theres a very bad idle it bounces around 1 and a bit under it. once it even got so frantic the car stalled at traffic lights.
    its very bad when driving too, for example from 1st pulling away there is no power at all and im flooring it, it feeling like 1/4 of the power coming through then it just kicks in i get the full power (goes normal again) then the cycle repeats when i stop and start. this happens only in 1st and 2nd, and it randomly jolts in 3rd(rarely) but after that early morning journey is over the car is great for the rest of the day.
    I have a cheapo VAG COM and software from ebay have yet to use it, gotta take out my stereo first as i heard it will cause trouble.
    does anybody know what the problem could be?, my clutch was bad i knew that and i thought that THIS problem was related(clutch slipping) but know now i know it can't be the clutch.
    S3KO4's Avatar
    Aug 2009
    London
    850
    Sounds more like MAF, have been said many times before, disconnect it and drive without it, if it feels any smoother then, you are in the right area.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    May 2009
    123
    k will search on it, but to speed it up can someone tell me where it is and how to remove it, im a complete engine noob
    EDIT: ok so i actually put in 'MAF' in the search box and seems like its too short a term, i tried "change MAF" but no results.
    any help?
    S3KO4's Avatar
    Aug 2009
    London
    850
    Open the bonnet, on the right hand side where the air intake box (air filter box) is, there is a round black object stuck to it, about size of a small drinking glass, with a cable connection, just disconnect (unplug) it, then drive it see how it feels, if it improves, then get a new one, make sure it is Audi VW, not cheap ones…
    May 2009
    123
    ok thank you, you have been helpfull i will try this soon.
    S3KO4's Avatar
    Aug 2009
    London
    850
    Good luck, keep us posted.
