JMB RetrofitsChris Nott
    May 2009
    36
    APY lambda sensor
    How many Lambda sensors are fitted to an APY engine as i can only find one located at the top of the down pipe beside the turbo, Do these engines only use one?
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    yep APY only has pre cat lambda
    May 2009
    36
    Thanks for the info, that should save a bit of hassle then.
