Sky InsuranceJMB Retrofits
Results 1 to 30 of 30
    Mattjbradbury's Avatar
    Mar 2010
    57
    How to Improving Handling
    I want to improve handling of my S3. High speed corners its got good grip, its slower speed corners where it understeers readily - due to the weight i would imagine - i was coming from a Polo GTi - 10mm lowered on stiffer springs which was like a go-cart.
    Would the best option be around 10mm lowering with stiffer springs? Does anyone know the best ones to get. I've been reading about the Gmbh 10mm lowering but hear thats expensive - Anyone reccommend other springs?
    I don't really want to go under 10mm as i don't want to bugger up ride quality too much. I'm going to replace my 17" avus wheels with 18" rstts soon too - so second question - whats the grippest rubber to get on these? I've always had good experience with Michelin, but hear Pirrellis are good too..
    Cheers guys...
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    I've been told that uprated ARBs improve the handling but don't affect the ride comfort. I asked a very similar question a couple of weeks back and ARBs were the answer.
    I too am upgrading to the 18 inch old RS4 style wheels soon as well. Will be looking for Michelin Contisports as I believe these are one of the best. Currently running P6000 on my Avus alloys and they are superb as well.
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Toyo R888 tyres are like slicks and super grippy but im sure you wont get many miles out of them, michelin pilot sport 2 are good tyres but cost a bit, im running pirelli p zero rossio which have good grip in wet/dry, get really good milage out of them and dont cost a fortune
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    Have a look in the stickys section theres a good thread on suspension setups. People rate the billy B8's with H and R springs which is a 25mm drop and have said this doesnt destroy comfort either. Speaking to the guys at TTS they recommend eibach springs over H and R for comfort (this might be because they sell them). The Gmbh kit should be cheaper than any other options, I'm looking at changing my dampers soon as they've seen over 100k, TTS said using the later TT quattro shocks and Eibach springs would be a good setup over standard, the later S-line TT on 18's was 20mm lower (this might have only been 10mm on the S3) over the standard TT on 17's according to them. Whats your budget like? B8's and HR springs plus fitting and alignment will cost about 1k, you'll also need to consider adjustable rear tie bars too. R32 ARB's are a good option to improve handling, but a combined package of uprated ARB's, shocks and springs gives the best handling setup.
    Mar 2010
    57
    Thanks for the Info. I haven't thought about budget yet, just wanted to get some info so i could see what my options are. I really don't want to lower too much. I think 20-30mm might be too much - not only for ride comfort but for the way the car looks. I want it to look as if its not been modded but handles better.
    I was thinking of just changing the springs and maybe dampers but saw on another thread that was not advisable... I want a handling boost for not tooo much money i suppose.
    Negaro Blue, Silver Recaros, 18" RSTT Wheels, Chrome Mirrors.
    JD09's Avatar
    Dec 2009
    3,080
    Damian from DPM Performance suggests ARBs would be the solution. I am looking for exactly the same thing.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,556
    I would get your 18s on first Matt and go one from there, the extra inch from your rims reduces body roll by a little and improves handling a bit also. If I'm being honest though, my S3 with Bilstein shocks and Eibach springs wouldn't stand a chance against my Mk2 Golf 16V on the twisty stuff in the dry. I did drive an S3 on coilovers lowered by 60mm though, and that handled very well at the expense of ride comfort though, it was bouncing all over the place, so not for me.
    Mar 2010
    57
    Cheers JD09 - Could you send me a link of it on their website if poss? I'm having a look but can't find it...
    Dane's Avatar
    Faster than a V12 Q7
    Cheltenham
    4,003
    I have the Billy b8 and -25mm eibach set up on my a3 tqs, the drop is nice and subtle, cruising comfort is better and its alot sharper when you push it through corners. My set up was about 650 fitted but that might be down to the difference in car? IMHO it's the right sort of mod for the car, it's discreet, it does everything you could need it to on the road and although it isn't cheap you know you're getting a good quality set up.
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by Mattjbradbury View Post
    http://www.dpmperformance.co.uk/
    Mar 2010
    57
    Yeah the weight is always going to mean its not going to handle like some. Its not bad at the minute, just wouldn't mind a little improvement to give it that extra bit of sharpness. I will put the 18's on first and go from there...
    Mar 2010
    57
    Also what speed rating to i need on the tyres for the RSTT 18inch wheels. Just looking on kwikfit website as an example and they say W,Y or Z for 225/40/18
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Uniroyal RainSport 2s for the rubber...
    http://www.tyrereviews.co.uk/Tyre/Un...ainsport-2.htm
    106 each from mytyres.co.uk. I just had 4 fitted yesterday and am now scrubbing them in a bit.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,291
    If you want any advise give us a shout and we'll be happy to talk you though the tried and tested options for the S3.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Mar 2010
    57
    Maybe a stupid question - but RSTT 18 Inch wheels have the same tire diameter whether fitted to the S3 or TT? Looking at a set that were on a TT on ebay...
    Mar 2010
    57
    Tyre even.. duuurrr
    RIP S3dave
    May 2004
    nr Glos
    7,175
    billies and H&R's springs & ARB's make for a nice planted quattro A3 setup
    lightweight wheels also will help make it feel more pointy - many reps are so heavy it dulls the turn in badly in my experience
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    Any one know when the search stopped working?
    Apr 2004
    12,521
    S3 Suspension and Set-up Guide /end
    Oh my bad seems to be working fine....
    JD09's Avatar
    Dec 2009
    3,080
    Just after I joined, around November time I seem to remember. . .
    (Joke).
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,556
    Yes, should be the same, 225/40R18s
    Sep 2006
    63
    In my experience the OE 17" Avus wheels are as heavy if not heavier then some 18" reps. Alot of the newer replicas are lighter then you'd think.
    Felixo's Avatar
    The Sarcastic one
    Mar 2010
    Republic of Ireland
    26
    I don't see Haldex Controller Upgrade being mentioned here, heard it does wonders in terms of handling. Who had it done and what's the verdict?
    '02/AMK Premenstrual Red Audi S3
    AmD Stage 2 Remap | MTM Clutch | Milltek High Flow | JBS Induction | Forge 007P
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    I have the Haldex upgrade and wouldn't really say it improves handling that much but does make it more fun to drive
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Felixo's Avatar
    The Sarcastic one
    Mar 2010
    Republic of Ireland
    26
    Quote Originally Posted by Andrew@A.L.D View Post
    Thinking of making it my next item on the list, would you strongly recommend?
  28. #27
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Re: How to Improving Handling
    Quote Originally Posted by VeVeX
    I agree, my RS reps were much lighter then the standard Avus.
    No one has mentionned that you should think carefully before upgrading the ARBs without sorting out the shocks first.
  29. #28
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Please give a review of the Haldex control!
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
  30. #29
    leshkin's Avatar
    Sep 2006
    Northwood
    678
    Quote Originally Posted by finesse View Post
    Some discussion on this here
  31. #30
    Jun 2009
    Leeds
    3,469
    If you have a lead right foot or big power its worth it
    FOR SALE
