EM TuningAH Fabrications
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    Silicone piping.....
    Whats easiest, fitting a 57mm (internal diameter) silicone pipe over an external diameter 60mm rigid pipe or......
    fitting a 60mm internal diameter silicone pipe over a 57mm internal diameter rigid pipe (which i suspect will be open to more leaks)
    I can't get hold of a 60-57mm reducer for my intercooler piping and need to do one of the above - the 60mm pipe in question is the Forge Map Sensor pipe
    anyone had the joys of trying either of the above
    Tim
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Ross_S4
    Aug 2009
    Dundee
    718
    never tried it myself on silicone, but I would imagine a bit of hot water to heat the end of the 57mm ID hose and ram it onto the 60mm OD pipe should be doable.
    It's all in bits
    Apr 2006
    Bristol
    219
    I would expect you should be able to get a 57 silicon hose over a 60. I know a 48 will go over a 51 alloy tube.
