Silicone piping.....
1animal1
The Clar!! it mouves!!!
Sheffield
Whats easiest, fitting a 57mm (internal diameter) silicone pipe over an external diameter 60mm rigid pipe or......
fitting a 60mm internal diameter silicone pipe over a 57mm internal diameter rigid pipe (which i suspect will be open to more leaks)
I can't get hold of a 60-57mm reducer for my intercooler piping and need to do one of the above - the 60mm pipe in question is the Forge Map Sensor pipe
anyone had the joys of trying either of the above
Tim
never tried it myself on silicone, but I would imagine a bit of hot water to heat the end of the 57mm ID hose and ram it onto the 60mm OD pipe should be doable.
I would expect you should be able to get a 57 silicon hose over a 60. I know a 48 will go over a 51 alloy tube.
17
977
696
6
770
887
