Volks AutosChris Nott
    Lancaster
    1,780
    Hard into gear after brake fluid change
    Our lasses car is hard to get into gear after I did the brake fluid change.
    I suspect its down to needing to now bleed the clutch fluid? The res' got abit low at one point, if my brother got bored and had pressed the clutch down. it could have air in?
    This all relies on if the A3 100 tdi Y reg has a fluid clutch?
    Chugger
    North Devon
    2,716
    lol you have answered your own question mate. Bleed the clutch, all will be solved
    57 A3 2.0 TDI Sportback (140)
    Lancaster
    1,780
    So they are fluid clutches then? I shall bleeeed it, any ideas as to where it is? I had a look the other day and couldn't see it.
    Sep 2009
    Essex
    2,366
    on top of the gearbox youll see the slve with hyd hose leading to it and bleed nipple
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,064
    Visit 16Klappe's Instagram Channel
    Quote Originally Posted by Matt82 View Post
    Unless it has the concentric slave cylinder which I think it might have with that year and being a TDI.
    I quite often say I'm going to do things.
    Then never do them.
    Lancaster
    1,780
    Easy to bleed though? My old vectra just a bleed screw on top of the box. I'll have to have another ganders when i put my new rear caliper on.
