EM TuningChris Nott
Thread: Loose Mirror!
    Els
    Els's Avatar
    Oct 2009
    Sussex
    80
    Loose Mirror!
    Hi chaps,
    My passenger side mirror is very wobbly, I don't think it will fall off but is this just a case of tightening something up?
    They are the alloy mirrors by the way.
    Imola Yellow S3
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    do you mean the miiror glass is wobbly or the mirror housing is wobbly?
    The mirror glass just clips in, try pushing it in
    I changed my mirror housing from red to chrome ages ago, but cant remember if its screwed on or just clips on. Maybe one of the screw holes inside the housing has broken (if you hit something).
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Els
    Els's Avatar
    Oct 2009
    Sussex
    80
    The whole mirror housing is wobbling.
    Is there a guide anywhere showing how you change the mirrors?
    Imola Yellow S3
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    not sure, i did the mirror housing without a guide, its pretty easy.
    Take the mirror galss out
    Remove the screws from the black plastic base plate under the mirror housing and then unclip it
    And then you can unclip the mirror housing from the frame (as i said, cant remember if there are screws holding this bit on)
    Alex S3 AMK
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    There are two bolts that hold the whole mirror on the frame. Put you window down, unclip the black plastic interior trim, this will reveal the two bolts
