Volks AutosJMB Retrofits
Thread: brembos
    Feb 2007
    enfield
    64
    brembos
    bought a set of secondhand lcr front calipers ages ago and put them in the garage and forgot about them.
    just found them again and look in need of a referb /paint /seals and dust covers.
    does anyone know were i can get the seals and covers ?are they a vag item ?also what paint to use?
    thanks steve.
    amd remap,brembo 4 pots,k&n,powerflex mount
    Aug 2009
    Gosport, Hants
    367
    Did a refurb on my Integra Type R Brembo's a few years back. You should be able to get a new seal kit from any SEAT dealer. Do they need repainting or just lacquering? If it's just the lacquer that has peeled off, leaving a pink colour, then they'll just need a rub down and relacquer. If you do paint, just match the colour, or choose any colour you want. It's the lacquer that's important. You will need a high temp lacquer, otherwise it will peel with the heat. You will also loose the Brembo logo if you rub down the paint, in which case you will need to get a brembo sticker from ebay or something to stick on afterwards.
    2003 Dolphin Grey S3, with a few mods....
    Feb 2007
    enfield
    64
    already got the stickers from ebay.thanks for the replly.
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    How much did you manage to pick these up for lad?
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    what size discs do these run?
    S3 Paul's Avatar
    Oct 2006
    2,764
    323mm discs from a seat leon cupra R
    Noggy Blue 2001 S3
