Boost problem
Bicknacre, Essex
Right....Drove my car to chelmsford friday, boosted n accelerated fine (over the last few though it has sounded like its making a bit more or high pitched noise from the turbo, like a wistling, but I just thought it was due to not having my door card on).
On the way home, can't remember if it was straight away or a mile down the road but I'm not getting any boost and the revs don't want to climb anymore than about 4000 and its soooo slow.
I creeped it home, whistling increases as you accelerate. Noticed there was a hole in the pipe that goes from the inlet manifold to the fuel regualtor, replaced that but it's no different, it idles fine but again the revs don't want to climb anymore than about 4000 and its really delayed.
Anyone know what the feck is going on? Could something of happened when there was a hole in the fuel reg pipe and I floored it?
if fpr did'nt see boost it would'nt have been rising rate pressure and would have run lean... worst case if sustained wot this is engine melting damage territory
your noise however may suggest a pipe is off or holed in the charge pipe run somewhere.. leak test to find it easier
11
762
9
710
21
2K
6
917
16
