Chris NottVolks Autos
Results 1 to 7 of 7
    clacton on sea,essex
    217
    Audi fault for audi brainers
    Hi all i have audi a3 1.8t 1998 model,started getting a slight judder at pull off and its bugging me as i cant/dont no what the problem is,when i pull of it some times dose this also if i am in 2nd/3rd at 30mph it seems like it shuts of the the cars alive again this only dose this a few times a day any answers ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Vacuum leak I suspect... check all the hoses/pipes coming off the inlet mani as a start for slipts and cracks etc..
    Block 032 in the engine group on VAGCOM will help to give you an idea of if you have a vac leak, a figure of 5% or more indicates ECU is adding fuel on idle....
    <tuffty/>
    217
    hi do u no if it could be a coil pack on its way out,or air flowmeter cheers,i dont no what u mean by block 032 ??
    leshkin's Avatar
    Speeding in reverse gear
    Sep 2006
    Northwood
    678
    Quote Originally Posted by audia3turrbo View Post
    Block 032 is a code for a bunch of data the the car's ECU will return if you monitor it via VCDS (vag-com). This code will give you information about your air/fuel mixture as seen by the lambda sensors. I would say that you need to find someone local with this software/cable and do some checking as you might have some errors codes logged, which will point you in the right direction. Here is a thread that will tell you who can help you.
    217
    Cheers any one eles have any comments
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Yes, trust Tufftybloke.
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,006
    Visit 16Klappe's Instagram Channel
    Yeah, if you haven't got a clue what it is how are you going to fix it?
    Just take it into a garage?!
    I quite often say I'm going to do things.
    Then never do them.
