Volks AutosChris Nott
Results 1 to 11 of 11
    Lancaster
    1,780
    Brake fluid change. 1.9 tdi
    I've been using our lasses A3 today and noticed the brakes are abit spongey. With no idea when the brake fluid was last changed. I got some fresh 5.1 today and setting about doing it tomorrow.
    Is there any specific way? MC first? or last?
    Cheers.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quite a few threads one this best practice is pressure bleeder and bleed the usual furthest away and work forward... bleed the MC last (2 nipples on the MC)
    5.1 fluid is actually a little spongier than dot 4. If you are looking for fluid that is less likely to fade under heavy braking then try Motul RBF 660, its a DOT 4 fluid but exceeds the spec of most dot 5x fluids
    <tuffty/>
    Lancaster
    1,780
    Cheers Tuffty, I was going to get 4. But the book in halfrauds said it needed to be 5.1 for some reason. Not too bothered about fade or boiling points. She only uses it to go to work and back so it's not getting a hard time at all.
    I shall go and start work on the old girl now.
    Lancaster
    1,780
    Had a fun time!
    Don't worry, I haven't just finished.
    Drivers side rear bleed nipple decided to snap flush. Nothing wanted toget it out. I took the caliper off to have ago at it in the vice but no luck, so had to try and bleed it via the pipe. Not ideal, but its got it back on the road whilst i get a fresh caliper.
    Its VERY spongey, but I suspect that caliper is just full of air. New caliper ASAP me thinks.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    its not nice when that happens....
    Lancaster
    1,780
    You're not wrong there! Just got a fresh caliper off ebay for 25 quid. The A4 goes in tomorrow for a clutch too. Allllll good fun!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by BlackQuat View Post
    Gotta love cars
    <tuffty/>
    Sep 2009
    Essex
    2,366
    buy a new nipple. get a drill (3mm for example) put a hole in the flush nipple, hammer in a good 4mm spline bit, impact gun it out
    Lancaster
    1,780
    Quote Originally Posted by Matt82 View Post
    Exactly what i would normally do.
    I driled it out to 3mm hammered in a spline socket and snap. Flush.
    Lovely!
    Sep 2009
    Essex
    2,366
    snapped the spline?! bad times. ive been using an S2 steel set for quite a few years now. apart from loosing them under the bonnet of the S4 theyre unkillable
    Lancaster
    1,780
    Mine were a halfrauds. Never mind, live and learn!
    Got my A4 back though, without the need for a flywheel. So quite happy there!
    Just waiting on a fresh caliper to come.
