AH FabricationsChris Nott
Results 1 to 8 of 8
Thread: Slow wipers
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,988
    Slow wipers
    More problems!!! on the A3 I have noticed the wipers are desperately slow, the fast speed is what normal speed should be....im thinking the switch or the motor...anyone?
    Tim
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Could be worth stripping the motor down mate. I had the same problem on a previouse car and the motor needed a bit of love.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,886
    Check to see if your wiper mechanism is seizing up, I think it's happened to someone else before on the forum?
    You've got to have a laugh!
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    ^^ What they have said really, MK4 Golf wiper spindles are known to seize up, I point the finger of suspision there....
    Last edited by Imteyaz; 13th March 2010 at 16:14. Reason: can't spell for toffee....
    Imteyaz.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,988
    will give it a go tomorrow..... just attempted the thermo which is twice as hard as my BAM..... bloody AUM
    recomdos's Avatar
    Feb 2004
    North East
    988
    Hi Tim,
    Did you manage to fix your wipers? I have the same problem with slow wipers (they stopped on me the other day when it was typically THROWING it down! D'oh). I'd like to dismantle it all and take a look at self fixing before replacing parts. Do you have any pics / how to guide?
    Rob
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    406
    Hi there. It's a fairly easy DIY job, as it'll be the drivers linkage that has siezed. Take the wipers off and the scuttle panel, then you'll be able to see the linkages. Spray some WD40 and try them on, make a note of the resting position, or take a photo for later. I sprayed mine for a few days to help strip it down, there's a circlip you've got to take out and then it should come apart. Use plenty of copper grease once freed and re-assemble.
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
    recomdos's Avatar
    Feb 2004
    North East
    988
    Quote Originally Posted by Watty View Post
    Cheers Watty,
    I'm guessing the first thing to do would be as you say spray the linkages with WD40 - then refit it all back together and check if it works? Failing this, do I take out the circlip and then do I strip the linkage or the motor mech?
