Chris NottMonster Motorsport
    Feb 2009
    Replacing the Brake Master Cylinder problems
    Hello all.
    I’m in the process of replacing the brake master cylinder on my A3. I’ve removed the two bottom bolts for the brake lines aswell as removing the right bolt attaching the master cylinder to the servo but i have no idea how to remove the left hand bolt of the master cylinder again attaching the master to the servo as it's virtually impossible to get to.
    Anyone got any ideas?
    Feb 2009
    Got it in the end. Had to use 2 socket extenders and a 1/2 socket. Tight fit indeed.
