EM TuningAH Fabrications
Thread: Clutch issue
    Oct 2009
    150
    Clutch issue
    Hi, jumped in my car this morning and the clutch pedal is stuck halfway down I was unable to engage gear whilst engine was running. Pumped pedal a few times still halfway down. Turned off selected second turned back on and drove. Can select gear fine now but pedal still halfway. Fluid level seems fine, any ideas? Please help
    Oct 2009
    150
    Right my car has been at at work since 6 this morning. I went out about 7.30 and took the cap off the reservoir and fluid level is fine. I've just been out now and pedal is back to normal. Any ideas?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Mine does the same bud, put your foot behind the pedal and lift it towards you then press it, do the a few times it'll come back up. Slave cylinder
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Yep. Might just be the Master cylinder, but TBH, sounds more like the slave cylinder, which is an engine/gearbox split job I'm afraid, so 6-8 hour job. Best to change the clutch and master cylinder at the same time. Get it to a specialist for a proper diganosis. Mine went last September, and cost me all 800 all in from APS Brackley, including the alignment afterwards.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    Oct 2009
    150
    Clutch pedal has been fine since. Hope it was just a one off
    shan00ble's Avatar
    Nov 2013
    south africa
    107
    Mine was doing the same thing. It got so bad that I was unable to select gears early in the morning. New master cylinder and all is well.
