Chris NottBadger5
    Oct 2009
    Fitting Forge TIP to AUM
    just tried fitting my forge TIP to my 1.8T but with no luck
    i had trouble with getting it in between the metal water pipe but i managed to bend it slightly so i could fit the pipe on the turbo but after that it wouldnt fit properly/square onto the air box. however if you fit it on square, the side of the pipe would rub on the engine?
    i couldnt work it out? after alot of fiddling i gave up on fitting it on the air box and tried fitting the breather hose's. well the thin little one fitted ok and so did the recirculating DV but the other one wouldnt reach and was probably short by about an inch and a half.
    has anyone else had problems?
    thanks Ro
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    sounds like you have the wrong one....Forge are normally bang on with fitment
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    Oct 2009
    hmmm, its got AUM part number on the packaging? do they do a GOLF MK4 AUM? as thats the code as well on it?
    Mar 2013
    Fareham, UK
    82
    I know we're 3 years on from this now, but did you have any luck Ro? Im looking to get a Forge TIP to fit on my AUM myself too, so just checking around to see others' attempts! CHeers.
