Sky InsuranceVolks Autos
    Sanj's Avatar
    Blue Beast
    Nov 2008
    174
    Passenger side door....
    Hey Guys, Help Needed!!!!
    I went to clean my car and noticed water leaking into the car from the top of the passenger side door..... had a look and theres a slight gap between the car body and the door sill, almost like someones tried to go at the door......
    I also noticed the door wasnt sitting flush, so I adjusted the metal catch (cant remember what its called) and nwo the door sits flush, and the gap is a little better, but theres still a slight gap. Any ideas on what i can do to fix it? I tried bending the door a little but scared im gonna break something..... was fine about a week ago.
    Help would be much appreciated before it starts to piss down!!!!!
    Current: Nogi Blue S3 BAM ⁞ Andy Mac sub ⁞ Forge 007P ⁞ TT Pedals ⁞ LCR Splitter ⁞ EBC Discs ⁞ Greenstuff Pads ⁞ Forge Short shifter ⁞ Spacers ⁞ Badger 5 TIP ⁞ Jetex Cone Filter ⁞ RTech Stage 1 Remap ⁞ 8P Gear Knob ⁞ N249 Delete ⁞ Oil Catch Can Mod
    Previous: MK3 Golf GTi 16v
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Mine was like this just last week..
    I had to adjust the striker on the car and the window frame.
    Sanj's Avatar
    Blue Beast
    Nov 2008
    174
    Quote Originally Posted by csweatherston View Post
    Thats the one, I adjust the striker already and the door sits flush, but still a very slight gap, What did you do to the frame?
    Mar 2010
    UK, SOUTH
    19
    take the door trim off and ya should be able to adjust the door frame from behind that. can adjust in/out and up/down. its easy to do once the trim is off.
    Sanj's Avatar
    Blue Beast
    Nov 2008
    174
    Quote Originally Posted by S3 NPD View Post
    Cheers man, I'll try it tom......
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Not necessarily easy....Its fiddely as hell i found.
    But theres some ally wedges which hold the window frame to the doorskin, these adjust how far left/right/in/out the frame sits once the doors closed.
    Make sure you mark all the bolts/ wedge positions before you undo anything, so you can put it back how it was if it doesnt go right.
