EM TuningAH Fabrications
Results 1 to 7 of 7
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    Boot self opening
    Do problems come in ones? nope!!
    Sat at some traffic lights earlier and the boot mechanism just started opening and closing...happend about 20 times then stopped when i pulled off, DIS showed boot open, next light it did it again.....and again and again then stopped doing it afer id closed the boot....then almost home after another 10 miles, then did it again!!
    any ideas?
    exorcism might be an option
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Another body in the boot, Tim?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Exorcism could solve all your problems but try to undo the rear panel first, unplug the switch , give it a clean, pray to god, then plug it back in, worth a try, could have a little moisture in there
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    cool...chars chaps
    i did wonder if it could be a puddle within the seals
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Quote Originally Posted by 1animal1 View Post
    cool...chars chaps
    May as well get a TVR for excellent reliability
    Have a look at the pressure switch at the lock mechanism. May be dirty or corroded
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    if the mechanism is rusted i.e mullard and the latch is moving, it will be pressing on the sensor and jibbing it out..
    19 from the stealers gets you a new lock. 2 screws and 2 10mm bolts later, you problem has gone!
    Now to many mods to list! Lots of power, torque and Leather!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    right just stripped it all down, took apart the pressure pads which are powered by a microswitch inside..... cleaned inside where there was no corrosion, refitted and upon connecting the left hand side, the mechanism moved....
    neither pad would open the boot etc o i ran a piece of wire across bth connectors - in summary i found that by unplugging one the other worked, both plugged in neither worked so one must have been stuck (microswitch)
    so im gonna replace both when i can get to the stealers next, anyone bought these yet? im gonna replace both as the one that does work still has moisture in
