JMB RetrofitsVolks Autos
Results 1 to 20 of 20
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    How to?? : Full Ambient lighting fitted for Ł5.21
    firstly i got to say this is a fiddly arse job! you will need.
    6 standard RED 5mm 12v leds (not ultra bright)
    1 soldering iron
    some electrical cable (able to hold 12v)
    2 red led caps
    4 standerd led holders
    2 chop blocks
    electrical screwdriver
    some insulating tape.
    Now before i start, i will say i know i could of used different tools i.e heat shrink and m/f connectors etc. In this case, i was using what i already had!
    Step 1
    Go to your local maplins and ask for 6 standard red 12v leds, 2 red holders, and 4 standard holders. They will then hand you a little bag like so...
    Ł5.21 down TA DAAA!
    carfully remove the interior light cover, and using a phillips remove the 2 screws holding it up. Carfully lifting the front of the roof lineing poke your wires through to the light fitting, like so..
    i simply split the wires from the chop block to power left and right LEDS. solderd the LED legs to the wire and wraped them in electrical tape. Run the Wires on the other side of the chop block along to your A pillar, tucking the wire under the lineing as you go along. gently lift the trim on the A pillar so you can access the wires from the door side. Pull down the rubber seal on the door and it will give you more room to access the wires from near the fuses.
    before anyone comments, the pillar pod was from my scooby, hence the uneven edges as i had to trim in to fit. The door rubber covers this so happy days
    i plumed into my already fused gauges so was simple from here. simply tap into the block. I have leaft my fuse as is as im only running 2 1w leds.
    I understand our cars will vary from trim. My pre facelift has no room for 2 symmetrical fitted LEDS so i impovised.
    using a small screw driver i peirced the roof lining. then poked a 5mm pozzi drive through the pircing. I think if you use a drill you mite do more damage than good by wrapping roof lining round the drill bit.
    I then popped these little red flat led holders in the hole.
    and the end result is this...
    I will do the footwells with the remaining LEDS as they are soft light leds. i will then has as per title.. Full ambient lighting for Ł5.21!
    Now to many mods to list! Lots of power, torque and Leather!
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Unless you have an S3 in which case you take the panel off, drill two holes and fit the Audi part
    Only joshing chap. Looking forward to seeing the floor lighting ones.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by JD09 View Post
    hahaha, wonderd how long it would take for that comment! lol *rolls eyes* bloody S3 boys!
    i too look forward to seeing my foot wells all done. Would of done them today but i had to come in as i was in to much pain to do em! (note to all, dont brake ya back) work 2morrow so i must add it to my list of "to complete" mods. Tho my center consoles nearly done!!
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    the Audi items will fit our facelift A3...ive already checked
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    see us poorpers with pre-face lifts have to opt for maplins! lol
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Er, mines pre facelift and has the stuff for the audi ambient lighting upgrade! How very odd!
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    well done for the effort...
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by A3Tom View Post
    mybe was an option thing? ?
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Maybe some sort of 'lighting' pack etc. as I've got puddle lights, rear seat reading lights etc, front map lights as well as the main big light at the front?
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    Alpine, have you got a lot of free time on your hands lately???
    27,099
    His is a 2000 car so it was most likely one of those anomoly 8L's that had some facelift parts whilst in middle of changing to facelift, so that would most likely explain Tom's
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    That makes sense.
    27,099
    Or he's just a greedy bloody copper who wants wants wants lmfao, but I'll go with my original & actual post lol
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by nilz18t View Post
    well people aint dieing! Plus my boss is being kind to me since i had my accident.
    27,099
    [QUOTE=ALPINE;931393]well people aint dieing!QUOTE]
    LMFAO had me pissing myself, sorry but what a post lmfao
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    [QUOTE=NHN;931395]
    Quote Originally Posted by ALPINE View Post
    glad to be of help! lol true tho.. no snuffy snuffy, = no jobby jobbys! devide that by wife kids and audi = lots of spare time on my hands!! lol
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    interesting....would be good to find if all facelifts have the puddle lights as our new one does..... but my old T plate didnt
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by 1animal1 View Post
    Sorry to sound dumb but what's a puddle light, is it under the doors to shine on puddles lol.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    DJ_Troopa's Avatar
    K1 Driver
    Oct 2008
    West London
    1,737
    Visit DJ_Troopa's Instagram Channel
    Quote Originally Posted by Lemon S3 View Post
    Yup! They're just 501 bulbs under the doors and come on when you open them.
    Inferi Black Cupra K1
    Click here for more Troo-Pics!
