Results 1 to 13 of 13
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    Driver door sensor!!!
    Right Please help me as I might be losing my mind with this.
    When It is a sunny day and I get into the car the dash display shows that the door is still open and the only way to correct this is to slam it shut is it just me or has the sun reflecting on it got something to do with it.
    Any help please!!!
    Aug 2009
    Gosport, Hants
    367
    I have this same problem, intermittently. I read a post on here a few weeks back saying something about a little plastic lever in the door lock which needs adjusting or something. Can be seen from the latch area.
    2003 Dolphin Grey S3, with a few mods....
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    I think I can remember something about that there was use of a screwdriver in the door lock or something like that!!!
    Aug 2009
    Gosport, Hants
    367
    Yep, that's it. Best I can suggest at the moment as I've yet to look at mine.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,176
    Really common problem, also happened to my S3. Did it in the summer when it was warm but not when it was cold. Problem is, when it thinks the door is open the interior light stays on & the alarm doesn't activate. There are lots of threads on here about it. Try this:
    http://www.audi-sport.net/vb/showthread.php?t=76603
    I gave up and had the senor replaced. Now all is good again.
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    same on mine happened, replaced the door lock mechanism which has the sensor inside, which is the culprit. Sensor sticks which still shows the door still open even thogh its closed!
    Unfortunately have to by the whole unit, and not just the sensor. When i bought mine 6months ago from audi they was 60
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,641
    You can do it without replacing the unit, I have done it on mine, you have to get a thin screwdriver, or a wire coat hanger into the locking mechanism and there is a awhite bit that needs to be pulled out a bit, you can see when you have got it, as the light at the bottom of the door will go on and off.
    If yuo do a search there are a couple of good write ups on this with pics
    Aug 2009
    Gosport, Hants
    367
    Maybe a stupid question but, are you still able to use the same key after you have changed the lock? i.e. is the key not cut to fit one lock only? or is that part of the lock different to the part you're on about?
    Nilz's Avatar
    Apr 2006
    9,641
    Yes you can use the same key, its just the locking mechanism that changes, although the car should have Central Locking on it, so you wont really need to use the key, will you??
    Aug 2009
    Gosport, Hants
    367
    No, not likely to use it, but if the battery dies in the key fob you need to unlock the door with the key and then put the key into the ignition within 10 seconds? to stop the alarm going off.
    dancarpy's Avatar
    S3 DCY
    Jul 2009
    Manchester
    236
    Quote Originally Posted by nilz18t View Post
    :D
    Nilz's Avatar
    Apr 2006
    9,641
    Dan the Man to the rescue
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    Thanks for the help Gonna attack the door with a screwdriver in a good way!!!
