Sky InsuranceVolks Autos
Results 1 to 16 of 16
Thread: n75 j valve
    105
    n75 j valve
    Hey guys just wanted to no if anyone has fitted the n75 j valve on there s3?how is this diffrent to the standard n75 valve and what does it do.ive herd that its have most of the vac pipes removed.any performance gains ect?
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Use the search facility, this has been asked several times before.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by s3 kam View Post
    Yes indeedy mate, I have.
    The N75 C/F is the stock item. The J valve is off the 225 TT and produces slightly more boost.
    The N75 valve is the ECU's method of controlling the boost. The way it works is by opening and closing the pipe to the wastegate, allowing boost through to the turbo's actuator as the ECU sees fit.
    It requires no pipework modifications to fit, and is a very easy 2 min job to be honest.
    It made such a difference to my APY engine when I fitted it. Bear in mind that it seems to be OK on the APY 210 engine - however this valve has a habit of bringing limp mode on on other engines for some reason (well - the reason is that it produces more boost and the ECU doesn't likey....).
    Same money from the dealer as the stock item, and IMO, well worth it.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    think i need to replace mine, welly how much was the n75j thanks
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Mine was 46.73+vat at the time last year ( 15% )
    Part number should be
    P A034 906 283 J
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    ive literally just ordered an N75F today - dealer quoted 75, so i asked my mate to order via his garage account - also 75 :/
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Chugger
    North Devon
    2,716
    there is a really good post on seatcupra.net about the J valve... http://www.seatcupra.net/forums/showthread.php?t=10170
    The J valve doesnt tend to bring on limp mode alot from what iv read, although the lucky buggers with APY dont have map sensors, so this is probably why it doesnt cause limp mode. Im not sure if it 'allows' more boost, but its slower to open the wastegate? something along those lines. I believe the J valve also has an adjuster, when adjust helps adjust limp mode. Anybody feel free to correct me, but this is what i have read. I wouldnt mind trying one if anybody wants to swap one for an F
    57 A3 2.0 TDI Sportback (140)
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    i had a convo with Mr Silverstone from JBS/Custom Code who says he hates the N75J's as they play havoc with his maps - never felt the need myself but thats becos im BAM
    105
    I have a bam to.mayb I shud leave it then.I really can't be doin with limp mode cuz I'm gettin it mapped this week.I fort the n75 j was jus removing the vac pipes.what's the j meen then
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    its the type of valve, internal settings.....its a direct replacement for the existing valve which will be exactly the same, bar the colour
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by sportstractor View Post
    I believe you're referring to the AGU which doesn't have a map sensor.... The APY most certainly does.....
    Homer Simpson
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Hmm how would one work on an AMK coded engine?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    TBH, they are a bit russian roulette if they work well on any car... I suspect they will cause more probs on a car fitted with a MAP sensor than they will on earlier cars as the ECU is more aware of whats going.
    If your car is mapped then I wouldn't bother as taking control of things like boost away from the ECU can lead to engine damage at worst or at least limp mode....
    AMK engine code has a MAP sensor btw
    <tuffty/>
    fran-s3's Avatar
    1,090
    Quote Originally Posted by Mr.G View Post
    Mines a AMK and my JValve worked great until is started going into limp mode a week later... Kept losing all boost until I restarted the engine so I sold it and went back to F... (APS remap) I also found it would certainly boost higher initially but tail of early compared to my original F valve... Sold it for as much as I payed for it on Ebay!
    Just my experience with it.
    Feb 2008
    2,810
    looks like with the amk models its not worth doing anyways
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    Chugger
    North Devon
    2,716
    my mistake
    for some reason i thought otherwise.
    It is strange how they work for a little while then start playing up.
