EM TuningMonster Motorsport
Results 1 to 9 of 9
    Apr 2009
    13
    110k miles s3 fidgity ride
    Fidgety ride, will not track straight, fidgets about when travelling in a straight line.
    I wonder if anyone can help, it could be, bushes, worn dampers, tracking, castor,
    Or ???
    I have checked camber ( 1 degree each side).
    It is also very sensitive to front tyre pressures, requiring them to be exactly the same on both fronts.
    Is there a reason that I can investigate that normally occurs at this mileage?
    Feb 2009
    Aberdeen
    2,523
    I'd guess ARBs and/or bushes. Had the same thing going on with mine, bushes were completely gone.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Apr 2009
    13
    thanks for the reply, probably get myself a front poly bush set.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,038
    I would be tempted to get an alignment test first in case its something simple...
    Bush wise, poly bushes are ok for the front of the front arms but stick to OEM TT/S3 non voided bushes for the rear bushes in the front arms... I found some bushes on ebay for about 8 quid the pair posted and they are fine. I have Powerflex in the front set of the front arms and the solid (non voided) rubber bushes in the rear of the arms (front arms have 2 sets of bushes). Poly bushes in the rear tend to squeeze out and split.
    Audi will try and sell you a replacement arm with bushes already in it (std bushes) as it is cheaper for them to replace the arm as a whole then to remove and press in new bushes labour wise...
    One other thing to check is the state of your tyres... when my fronts start getting a bit worn the car tends to track a little more....
    <tuffty/>
    Jul 2007
    Wiltshire
    210
    go for a 4 wheel Laser Alignment. and check Tire wear on the inside Think its about 80 Not a bad price and it will feel like new
    2006-7 Audi S3- 99...Sold
    Honda CBR600RR...Sold
    2009-10 Audi S3 01...Sold
    Suzuki GSX-R 1000 + Suzuki RM-Z450.... KEEPING
    2011 Wants another S3...........
    AudiiduA's Avatar
    Midlands
    358
    I had a similar problem on a Celica few years ago, it needed track rod end ball joints! wich made sense as there was play in them and the tracking was constantly altering slightly over bumps ect! had them fitted and then tracked and it was like new!
    ATB Lee
    martin g's Avatar
    [censored]
    somerset
    154
    anyone know of a place to laser align in the somersetish area??
    jesters3's Avatar
    The Shire's
    1,516
    Mine had a fidgety rear, came down to replacing the ARB Droplinks (15.00 a side and 5 mins on a ramp) as the original ones had some play in them
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Sep 2009
    Essex
    2,366
    at 110K miles the bushes will be well past their best. the front end is so simple to do, id start there and maybe drop links
    ive not played about with the rear end of an S3 (independant) but i cant imagine those bushes being particularly good either
