EM TuningVolks Autos
View Poll Results: Unreasonable charge for Servicing ?
Voters
5. You may not vote on this poll
  • Job was done quickly and correctly
    1 20.00%
  • Job was done quickly but incorrectly
    0 0%
  • Job was done slowly and correctly
    0 0%
  • Job was done slowly and incorrectly
    4 80.00%
Results 1 to 7 of 7
    spiker's Avatar
    usually growling at something
    Jul 2005
    Thornbury
    200
    How Much ? for a Thermostat ?
    do you have to remove the inlet manifold to replace the thermostat ?
    My local independent added 3 extra hours of labour
    4hours 20 min for an oil and filter change - temp sensor change and thermostat change
    Does this sound unreasonable ?
    If you aint first you're last
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,023
    IMO, no... inlet mani does not need to come off... the most difficult bolt to remove is the bottom one of the housing.... this can be got at by using a 1/4" 10mm socket on a wobble extension or by removing the 2 bolts holding the alternator on and moving it out of the way...
    Granted removing the inlet mani gives more access but once you remove the trim and plate on the front of the mani you have as much access as you need and would still have the problem of the difficult lower bolt...
    <tuffty/>
    Chugger
    North Devon
    2,716
    nice poll, i did mine without removing it or the alternator.
    Ideally the alternator needs to come off tho.
    57 A3 2.0 TDI Sportback (140)
    Aug 2009
    14
    I had my thermostat replaced back in November last year to fix the dodgy dash reading. I sent the well known change thermostat instruction page to the mechanics.. Just in case.
    He told me that he started doing it the way the link said, then goes hey why not just pull out the alternator and away we go..
    Looking at the invoice just now, it seems they took less than 2 hours to do the work..
    The bill including thermo and new v belt (which was knackered) and coolant and time was 86 quid..
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Access to the thermostat housing is a bit tricky but I managed it by just moving the cable from the alternator out of the way. I'm no pro and I managed it within an hour.....so I'd say the garage that did yours are pulling your pants down over it.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    vetch's Avatar
    S3
    Apr 2009
    412
    Mattoo I think you've misunderstood the poll.
    Audi S3
    spiker's Avatar
    Jul 2005
    Thornbury
    200
    Thanks for the replies so far - Im starting to think I need to change my independent
    Any recommendations on Audi/volks garages in the south West - I am just north of bristiol
