JMB RetrofitsEM Tuning
Results 1 to 22 of 22
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Haldex Controller question
    Had a VAGCOM check on my 2001 S3 at a local garage. Garage came back and said that, amongst other things, the "Haldex controller is faulty and needs replacing". My heart sank a bit when I was told that this equates to approx 750 inc VAT fitted for a new one.
    So I ran a quick check through some threads on here and found that if I put my car on a ramp, start it, engage 1st gear (or any gear) and accelerate then all 4 wheels should rotate. I did this and all 4 wheels did indeed rotate.
    Am I missing something or is the Haldex controller working completely fine?
    Additionally, I checked my Vagcom report for a "Haldex controller is faulty" code and found this code.
    "65535 - Internal Control Module Memory Error" Is this the Haldex Controller or somehting else? (searches seem to suggest either controller or airbags.
    Any help gratefully received as I dont want to spend 750 if the Haldex is fine.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Welly, The thread you link to is EXACTLY how my car is behaving. However, the answer to the thread is simply "get a new controller". But why? There is no real explanantion to suggest that the haldex controller is faulty (apart from the VAGCOM code, which still doesn't tell me much).
    Anyone any thoughts?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Sorry bud, HALDEX systems not really my speciality....
    I'd just come across the link before.
    Here is another one which may be useful....
    http://uk-mkivs.net/forums/p/37544/816993.aspx
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yet more:
    http://www.tt-forum.co.uk/forum/view...5972&p=1587058
    This one mentions fitting an uprated haldex unit...
    Homer Simpson
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Hmmm, having read the second link, it would seem that the "Haldex controller is faulty". It is interesting that lots of people have had this problem and that it might be caused by a faulty ecu. If indeed the ecu is faulty then I would point back to the manufacturer.
    My soltuion to this is to first ask the local dealer and gauge their thoughts. I imagine this will involve a short conversation about replacing the haldex controller.
    Secondly I will go back to Haldex (the original Swedish company) and see what they say.
    I'll post an update when I have one.
    ps - cheers Welly for the good finds.
    Rob
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    For that price get a performance one and fit yourself or get a garage to fit it for a hours labour ( 1 hour = about 40 )
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Hmmm, how much money should I be looking at if it is the haldex controller then? Either oem or aftermarket one?
    S3KO4's Avatar
    Aug 2009
    London
    850
    Are you spining in wet/dry? does the car shake under hard accelerations? if the answers were all no, then I would leave it until you spin. in the mean time keep an eye on ebay, you could get them from r32 and v6 4motions mk4 or TTs should be able to pick one up for around 150
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    S3KO4's Avatar
    Aug 2009
    London
    850
    They are all OEM, you can get uprated ones, painted blue or orange, offer 50/50 really good for big power. but extra load on the rear diff.
    Audi: 647
    Ebay Blue/Orange uprated: 650
    Ebay OEM: 100-250
    Jun 2009
    Leeds
    3,469
    Blue ones are for the early S3's and the Orange ones are for the later S3's
    FOR SALE
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Thanks for the prices. All good stuff.
    In response to S3KO4 - No the car does not spin any wheels (in the wet or dry). No the car does not shake under hard acceleration. I have tried a few hard launches on dry tarmac (it has not rained here in a while) and the car seems fine. I am looking to conduct some hard launches on some wet grass to see what happens then.
    So far, the car seems fine to my untrained eye. I am frustrated that I cant sem to explain the fault code as diagnosed through VAGCOM (Haldex error 65535 internal control module memory error - see link in earlier reply from Welly). I have emailed "vagtech.co.uk" to see if they have any more information on the fault code and to see if they can shed any more light. I am hoping that the error code is an internal software glitch with the ecu and that everything in the real world is actually fine and working as it should.
    Updates as I get them.
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    seems like theres nothing wrong with it, wait for the rain turn the esp off & lauch it when turning onto a new road. You should instantly be able to tell if its working or not.
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    s3ollie's Avatar
    Jan 2007
    749
    i had the 65535 code on my old s3 and that was related to the air bag module what section did you get that code from on your scan?
    do you have an airbag light on the dash on?
    8P S3
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Quote Originally Posted by Andrew@A.L.D View Post
    Do the later 8P Haldex controllers fit the 8L, and does it do the same job as a performance haldex controller?
    s3ollie's Avatar
    Jan 2007
    749
    i thought the color was like this
    silver- standard.
    blue- uprated.
    orange- race.
    all for the 8L
    i believe the orange one keeps the rear engaged under braking also to help slow the car down
    8P S3
    s3ollie's Avatar
    Jan 2007
    749
    8P S3
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Ollie,
    The fault code is in the AWD section. It looks like this on the report
    Address 22: AWD Labels @ 02D-900-554.1B1
    Part No. 02D 900 554 B
    Component: HALDEX LSC ECC
    2 Faults found
    065535 - Internal contorl module error
    00526 - Brake light switch
    Again, as stated, I am awaiting replies from VAGTECH and HALDEX themselves
    Rob
    Jun 2009
    Leeds
    3,469
    Quote Originally Posted by jojo View Post
    No
    Different inside and out
    FOR SALE
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    No
    Thanks.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by S3KO4 View Post
    Is this a symptom of a FUBAR Haldex controller? Got issues with my S3 at the moment with shaking such as this - and the TC light is always on. I thought that was probably a Long/Lat sensor. I'm just too lazy to go and scan for codes.... LOL.
    Homer Simpson
    Aug 2011
    6
    Red face
    Quote Originally Posted by RobW View Post
    Ollie,
    2 Faults found
    Rob
    old post but anyway... I got my S3 on july and finally the other day I scanned it and I got this same 2 errors on haldex, my car haldex works ok no spinning, sometimes the ASR light turns on for some reason and when I turn off the car it turns off...
    greetings
