Haldex Controller question
RobW
Run Rob Run
Portsmouth
Had a VAGCOM check on my 2001 S3 at a local garage. Garage came back and said that, amongst other things, the "Haldex controller is faulty and needs replacing". My heart sank a bit when I was told that this equates to approx £750 inc VAT fitted for a new one.
So I ran a quick check through some threads on here and found that if I put my car on a ramp, start it, engage 1st gear (or any gear) and accelerate then all 4 wheels should rotate. I did this and all 4 wheels did indeed rotate.
Am I missing something or is the Haldex controller working completely fine?
Additionally, I checked my Vagcom report for a "Haldex controller is faulty" code and found this code.
"65535 - Internal Control Module Memory Error" Is this the Haldex Controller or somehting else? (searches seem to suggest either controller or airbags.
Any help gratefully received as I dont want to spend £750 if the Haldex is fine.
Welly, The thread you link to is EXACTLY how my car is behaving. However, the answer to the thread is simply "get a new controller". But why? There is no real explanantion to suggest that the haldex controller is faulty (apart from the VAGCOM code, which still doesn't tell me much).
Anyone any thoughts?
Hmmm, having read the second link, it would seem that the "Haldex controller is faulty". It is interesting that lots of people have had this problem and that it might be caused by a faulty ecu. If indeed the ecu is faulty then I would point back to the manufacturer.
My soltuion to this is to first ask the local dealer and gauge their thoughts. I imagine this will involve a short conversation about replacing the haldex controller.
Secondly I will go back to Haldex (the original Swedish company) and see what they say.
I'll post an update when I have one.
ps - cheers Welly for the good finds.
Rob
Hmmm, how much money should I be looking at if it is the haldex controller then? Either oem or aftermarket one?
Are you spining in wet/dry? does the car shake under hard accelerations? if the answers were all no, then I would leave it until you spin. in the mean time keep an eye on ebay, you could get them from r32 and v6 4motions mk4 or TTs should be able to pick one up for around 150
They are all OEM, you can get uprated ones, painted blue or orange, offer 50/50 really good for big power. but extra load on the rear diff.
Audi: 647
Ebay Blue/Orange uprated: 650
Ebay OEM: 100-250
Thanks for the prices. All good stuff.
In response to S3KO4 - No the car does not spin any wheels (in the wet or dry). No the car does not shake under hard acceleration. I have tried a few hard launches on dry tarmac (it has not rained here in a while) and the car seems fine. I am looking to conduct some hard launches on some wet grass to see what happens then.
So far, the car seems fine to my untrained eye. I am frustrated that I cant sem to explain the fault code as diagnosed through VAGCOM (Haldex error 65535 internal control module memory error - see link in earlier reply from Welly). I have emailed "vagtech.co.uk" to see if they have any more information on the fault code and to see if they can shed any more light. I am hoping that the error code is an internal software glitch with the ecu and that everything in the real world is actually fine and working as it should.
Updates as I get them.
seems like theres nothing wrong with it, wait for the rain turn the esp off & lauch it when turning onto a new road. You should instantly be able to tell if its working or not.
i had the 65535 code on my old s3 and that was related to the air bag module what section did you get that code from on your scan?
do you have an airbag light on the dash on?
i thought the color was like this
silver- standard.
blue- uprated.
orange- race.
all for the 8L
i believe the orange one keeps the rear engaged under braking also to help slow the car down
Ollie,
The fault code is in the AWD section. It looks like this on the report
Address 22: AWD Labels @ 02D-900-554.1B1
Part No. 02D 900 554 B
Component: HALDEX LSC ECC
2 Faults found
065535 - Internal contorl module error
00526 - Brake light switch
Again, as stated, I am awaiting replies from VAGTECH and HALDEX themselves
Rob
Is this a symptom of a FUBAR Haldex controller? Got issues with my S3 at the moment with shaking such as this - and the TC light is always on. I thought that was probably a Long/Lat sensor. I'm just too lazy to go and scan for codes.... LOL.
Ollie,
2 Faults found
Rob
old post but anyway... I got my S3 on july and finally the other day I scanned it and I got this same 2 errors on haldex, my car haldex works ok no spinning, sometimes the ASR light turns on for some reason and when I turn off the car it turns off...
greetings ;)
10
2K
897
940
