Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Mar 2010
    7
    My S3 ran a bearing lastnite :(
    Hi All
    Is this common?
    The oil pump and turbo was replaced not to long ago. The car had a major service done about 3 weeks ago. I was using Magnatex oil before i used shell.
    Any comments.
    Stripping tonight.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Dhaafier View Post
    Hi All
    Is this common?
    Any comments.
    Stripping tonight.
    I wouldn't of called it common mate, no to be honest.
    What sort of noise did it make?
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Mar 2010
    7
    Oil pressure light came on. I switch off. Drove again light came back on and heard i rumble and then a really loud rumble like a diesel engine lol...
    What bearings you guys recommend?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I used ACL race bearings which are cheaper than factory shells. http://cgi.ebay.co.uk/Audi-1-8T-Big-...#ht_1040wt_939
    Audi factory bearings are fine, but not cheap.
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    I used Audi bearings for mine... just make sure whatever you use are tanged as tang less bearings can spin on the journals...
    <tuffty/>
    Mar 2010
    7
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Are you talking about the lip to hold the bearing
    Mar 2010
    7
    Im from South Africa.. So will see where i can source them.
    How long does the oil pump last?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Hmmmmmm...... Tangy! (drum roll)
    Much more info here....
    http://www.patentstorm.us/patents/41...scription.html
    Homer Simpson
    Sep 2009
    Essex
    2,366
    CRAP. id do a lot of searching find out what caused the oil pressure issue.
    any clues so far?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Matt82 View Post
    any clues so far?
    Blocked oil pickup or bust pump are the normal culprits....
    Homer Simpson
