Monster MotorsportVolks Autos
Page 8 of 15 FirstFirst 123456789101112131415 LastLast
Results 281 to 320 of 595
Like Tree3Likes
Thread: Oil Catch Can mini group buy anyone? including PCV system simplification.
  1. #281
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by Westle View Post
    Cheers for the update Ollie. I think i'll get myself a silicon TIP before I attempt this job so that the hose is made to measure.
    No probs, think my Autobahn TIP was only 60 ish, and is good quality.
    2003 Dolphin Grey S3, with a few mods....
  3. #282
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,176
    Great pictures OllieH, very clear now. Doesn't look like you were in a rush!
    A few questions before I do the installation:
    - What did you block off the various un-used pipes/connectors with?
    - How do you drain the can? Even with the relay box removed, access to the bottom of the can looks pretty tight.
    - Finally (!) don't you need any pipe clips on the various new connections, or will they be secure without?
    Thanks again for the guide.
  4. #283
    Aug 2009
    Gosport, Hants
    367
    The Doctor
    Cheers pal.
    This picture shows the sort of room there is. The strut bar is removed here but even when fitted there's enough room to get a small pot under there and unscrew the drain tap.
    As for the blanked off connections, the only one that actually needs blanking is the one on the underside centre of the inlet manifold, shown here:
    Can't remember what size hose it is, 3/8" or 1/2", it was a piece from the pcv pipework I had taken off. All I did was find a bolt that fitted the ID of the pipe and jubileed it in.
    The connection on the left hand end of the manifold is reused for the brake servo feed, with check valve inline:
    As described a couple of pages ago, this is just a temporary fit until I can get some silicon pipe and another check valve to replace it.
    The only other connections on the inlet manifold are the two feeds to the N249/DV and the FPR.
    For the moment I've only put a jubilee clip on the PRV to TIP connection as it's quite tight and kept wanting to pop out. The other connections seem secure but I'll be fitting jubilees to them this weekend anyway
    Just to add, if you get stuck at any point and need some advice, feel free to post here or pm me and I'll see if I can help.
  5. #284
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    Hiya chaps.....finally finshed mine on the A3 today..... heres a few pics that i posted in my build thread
    thanks again for putting this buy together Ollie - top man!!
    Tim
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
  6. #285
    Aug 2009
    Gosport, Hants
    367
    No probs pal.
    Yours is looking good, a stealth install aswell. Looked into fitting mine like yours but there isn't the room on the S3 to pipe it that way. The N75 gets right in the way.
    Where did you get your check valve from thats on your servo feed? I need one like that.
  7. #286
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    was already in line mate...... i just replaced the piping around it....... sure you could order one for an AUM A3 easily enough
  8. #287
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by 1animal1 View Post
    Yeah probably, will have to have a look.
  9. #288
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    id just nip to a local breakers mate...... nobodies gonna want that piece
  10. #289
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    True, all the one way valves seem to come with the vac pipe attached according to ETKA and are expensive to buy new, better to get one from a breakers yard for pennis than to spend 10+ for a whole pipe.
    I still haven't managed to get mine fitted, work commitments getting in the way but as soon as I do fit it, I'll post some pics up too. I'm gonna attach my can to the battery box so it will look like the one in the link posted from the UKMKIV's forum.
    Imteyaz.
  11. #290
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by Imteyaz View Post
    Sounds like a plan. Will have to find a breakers that hasn't converted to one of these 'request the part you're after websites'!
    Will be interesting to see the battery box install when you get it done. When I looked I couldn't see a good enough way of mounting it without it looking tacky, and there wasn't much room to drain it either with it sitting almost right on top of the gearbox.
  12. #291
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,078
    Well, it's a bit late, and not entirely related as I've used a different can, but I thought I'd add my efforts into this thread to save posting elsewhere.
    I didn't want to spend a fortune on the can you guys used, so invested 29 in an ebay jobby, and the quality is incredibly good, the top didn't seal 100% when I got it, but I made a gasket from a cereal box, and it's sealled down really well.
    I couldn't find anywhere behind the TIP to mount the can nicely like Tim did, I'm going to modify the engine covers so tehy still fit when I get a chance.
    Here's the pics:
    Just after I started, I fitted the can itself last week when I had a bit of spare time. I removed the battery, and drilled the side of the battery box to mount the plate. I had to trim the fins off the back of the box to get the can to sit square. Two cap headed allen bolts and it's in there nice and tight.
    At this point I'd removed the Y piece from the rocker cover, but the rest is still in
    With everything ripped out, you're left with this bit. Attach your chosen breather hose to the end, and refit it into the crank case, making sure the sealing ring sits properly
    Here's the finished article. I'm not totally happy with the pipe I used to be honest, it's oil resistant bilge hose, but it's a bit too flimsy for my liking, so that'll get replaced.
    Aside from the cheap nasty hose, I'm really happy with it. it's solidly fitted, easy to drain where it is, and it's done away with the chance of PCV related boost leaks, and stops the IC filling with oil.
    Job done, and all for 35
  13. #292
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,176
    Really need to get mine fitted. Just haven't had/found the time to do it yet.
  14. #293
    Netherlands
    33
    Hi Prawn,
    nice work! Got an ebay link?
  15. #294
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,078
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
    that's the can I bought mate, in black of course so as not to look too gay. Very nicely made too. impressed for such little money. It's all assembled with decent threads, rubber O-ring seals, and a knurled alloy drain plug on the bottom.
  16. #295
    Netherlands
    33
    Tnx mate, i'll one this week!
  17. #296
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,166
    Just ordered my Autobahn TIP and some 3mm and 4mm silicone piping. Just need to source some jubilee clips and 2 90 degree pipe bends and I'll be ready to fit.
    Just re-read this entire thread again and it all makes crystal clear sense now.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  18. #297
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    If your wanting some 19mm 90 bends, then i got some off ebay, their spot on, only problem their blue and my silicone pipings red, lol.
  19. #298
    Westy's Avatar
    Dec 2008
    17,166
    I want black ones mate but the original link that Ollie posted above has expired and the same shop dont seem to stock them any more. I also need to get some jubalee clips which i might get on the day.
    S3 Build Thread
  20. #299
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Well if you manage to find some black one's, let me know, the blue doesnt go as well as what black would, no where seems to do black though.
  21. #300
    Westy's Avatar
    Dec 2008
    17,166
    Just found these:
    http://www.dan-koi.co.uk/subcat1085.html
    The 90 degree elbows are half way down the page for 69p each! I might try to get these from a local aqaurium or something so I dont have to wait for delivery.
    S3 Build Thread
  22. #301
    Westy's Avatar
    Dec 2008
    17,166
    Found these on the bay too but a bit more pricey. but they actually work out cheaper with the postage compared to the fish place in the previous link:
    http://cgi.ebay.co.uk/Hose-Pipe-90-D...item2a0169ec6e
    Just bought 2
    S3 Build Thread
  23. #302
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    The only thing that would concern me is the thickness of them, the blue ones i have are solid as. If the ones in the first link are any good, may order them, cant go wrong for 69p lol.
  24. #303
    Westy's Avatar
    Dec 2008
    17,166
    I'll let you know how it goes with my ebay ones.
    S3 Build Thread
  25. #304
    Aug 2009
    Gosport, Hants
    367
    That must have took some time.....it's huge lol.
  26. #305
    Westy's Avatar
    Dec 2008
    17,166
    Quote Originally Posted by OllieH View Post
    Yep it did take a few hours but I now know exactly what i'm doing. Just waiting on my hose, elbow joiners, and TIP
    S3 Build Thread
  27. #306
    Westy's Avatar
    Dec 2008
    17,166
    Another question to pose to those who have already fitted their can.
    What actually needs to be jubalee clipped? I noticed in Ollie's pics he hardly has anything clipped and wonder what pipes are the ones most likely to need clipping. I'm going to get all the necesary clips this weekend.
    Cheers guys
    S3 Build Thread
  28. #307
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,078
    Well, in theory, none of it is ever under any pressure, and very minimal vacuum too. depending on how tight your hoses are into the fittings you could run it without any clips at all. if the hoses are a loose fit though you'd need to clip it to avoid any vacuum leaks.
  29. #308
    Sep 2009
    Essex
    2,366
    this weekend im starting on building a kit to replace the breather hoses under the manifold that like to split.
    im looking to just down size the rubber hoses silghtly to make a tight connection and see if it can function without clips. 8mm on the 10mm nipples etc. as prawn said, the vacuum is minimal but as long as it holds boost im happy, so the boost leak kit is coming out too
  30. #309
    Westy's Avatar
    Dec 2008
    17,166
    Thanks guys. I'll probably try and clip it all anyway just to be safe. I'll probably be able to reuse most of the old TIP clips on my new TIP so will just need to buy a few more to cover myself.
    S3 Build Thread
  31. #310
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    Going to fit mine today
    I ended up getting this one
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_1031wt_980
    Not the cheapest but very good bit of kit
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
  32. #311
    Jun 2003
    133
    Has anyone who has fitted the OCC replaced the check valve in the pvc system with a new valve, if so where did you purchase it from?
    Black Audi S3 | 254bhp 274lb-ft MTM Chip | Samco Hoses | AMD Viper DV | Neuspeed ARB | Bilstein shocks | H&R springs --Andy--
  33. #312
    Aug 2009
    Gosport, Hants
    367
    Quote Originally Posted by AndyS3 View Post
    I got rid of mine altogether matey. I think everyone else has aswell who has fitted this. You're on about the pcv non return valve which comes off the crankcase breather??
  34. #313
    Jun 2003
    133
    Sorry abit unclear, i meant has anyone used a new check valve to the brake servo or just used the one from pcv system? If they have replaced it with a new one where they get it from.
  35. #314
    Aug 2009
    Gosport, Hants
    367
    Ah ok. No, I have just used the old one for now. I plan on gettin one of the 'two port' check valves used on the A3 from a scrappy at some point, to replace the 'three port' one I've got now which has one of the ports blanked. You can't buy just this check valve from the dealer unfortunately.
  36. #315
    Westy's Avatar
    Dec 2008
    17,166
    I fitted my Autobahn TIP and catch can this weekend and it was a nightmare! It took about 5 hours for everything and I ran into one major issue with trying to get the Hocky Puck valve to fit directly on the TIP!
    Ollie I have no idea how you managed to get it to fit directly onto the TIP because I tried everything. I even tried filing the lip off the valve and I had to trim a bit off the TIP because I'd rucked up the silicone so much! In the end I had to use a piece of the old system which was a smaller diameter as a joiner to get the valve on, I hope that wont cause a problem!!!!
    I also ended up blowing out the nut and bolt I'd used to block off the hose under the inlet mani, but that's sorted now.
    Car hasn't been overly happy since I did this either, and threw up the EML yesterday with the following errors. I think this is where the inklet mani bolt had come out though:
    17963 - Charge Pressure: Maximum Limit Exceeded
    16497 - Intake Air Temp. Sensor (G42): Signal too high
    17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
    16487 - Mass Air Flow Sensor (G70): Signal too High
    I'm off to check out the AIT error and Exhaust gas error on Ross-Tech.
    S3 Build Thread
  37. #316
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    id guess the same too mate... that would all be related in my mind.......
    TIP is easy......the can takes a lot longer than you think
  38. #317
    Westy's Avatar
    Dec 2008
    17,166
    Yeah can was a whore! The main stumbling block was with the hocky puck valve not going into the tip directly, I've used a thin piece of pipe with each end covered in electrical tape to pad it out but I'm worried that this is now a bottle neck in the system plus the electrical tape is going to get hot and drop off.
    I might buy one of these (http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT) to try and make it fit better but I dont understand how others have plumbed there's directly into the TIP, especially Ollie who has the same TIP as me!!!
    S3 Build Thread
  39. #318
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    dunno mate, i know it went onto the standard tip on the A3 with no problems.....i would assume the silicone would be the same diameter...... although the puck doesnt sit on the tip normally on the S3 does it? like it does on the A3
  40. #319
    Westy's Avatar
    Dec 2008
    17,166
    I just followed Ollies guide mate so I thought it would be nice and easy!
    I checked the botch job when I got home from work and the tape is starting to come loose already so i've just bought that hose joiner. I might have to buy a new hocky puck too as I hacked mine up a bit to try and get it to fit!
    S3 Build Thread
  41. #320
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    15-20 IIRC mate from Stoke Audi...i priced one in one of my last requests
