Sky InsuranceChris Nott
Page 14 of 15 FirstFirst ... 4789101112131415 LastLast
Results 521 to 560 of 597
Like Tree4Likes
Thread: Oil Catch Can mini group buy anyone? including PCV system simplification.
  1. #521
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    Quote Originally Posted by S3 Nattie View Post
    Thats a good guide but im with you about not wanting to put the oil back into the sump after seeing some of the pics in this thread.
    The trick i've found when emptying the can is to do it when the engine is as hot as possible. If i empty the can when the engine is cold I dont tend to get as much out as I think the oil is thicker when cold.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  3. #522
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    [QUOTE=S3 Nattie;1225594]How did you bore out the ports Dave. Do you know if the one I linked has a baffled inside.
    QUOTE]
    I Just took the connectors off and drilled the ali out to 19mm just left a bit at the bottom to stop my 19mm stainless tube dropping through i can give you a couple of pieces if requierd, mine was baffled ask him....
  4. #523
    Syvo's Avatar
    IF IN DOUBT GO FLAT OUT
    Jan 2011
    warrington
    1,337
    Quote Originally Posted by Westle View Post
    This is a very interesting guide too:
    http://www.034motorsport.com/images/..._Catch_Can.pdf
    Looks like you can get a hose that will recycly the oil back to the sump! Personally, after seeing some of the crap that comes out of the can I wouldn't want to put it back in the sump
    this makes more sense than the guide of the first page link is this all you need to do or do you have to remove all the pipes under the inlet manifold also?
  5. #524
    Westy's Avatar
    Dec 2008
    17,273
    When I get home later I'll get the pics of my bay to show how the hose from the inlet mani goes.
    Basically all you need to do is block off the hole under the inlet mani. The hose that comes off the left of the mani and goes to the brake servo can be a normal length of silicone but it must include a 1 way valve somewhere in that hose otherwise you'll have no brakes.
    My pics will make it all clear
    S3 Build Thread
  6. #525
    Westy's Avatar
    Dec 2008
    17,273
    Ok as promised here are my pics.
    Firstly here's my diagram again so you can follow it with the pics:
    Here's the can with it's in/out hose:
    The top hose comes down under the TIP and joins to a t-piece. This then goes up to the rocker cover and off to the 90 degree pipe on the oil filer housing. Here you can see the rocker cover route:
    Here is a close up of the T-piece taken from the left side of the battery:
    You cant see the hose from the top of the can in these pics but the red line shows the hose to the rocker cover and the blue line shows the hose off to the oil filter:
    Here is where it joins the 90 degree bend on the oil filter housing below the inlet mani:
    So that's the top pipe on the diagram done. The side pipe out of the can goes down and into the hockey puck which then vents into the TIP as shown here:
    Red line shows the hose coming from the side of the can, hockey puck is obvious, the blue line is heading to the TIP and the green line is the TIP:
    With all that done that's the hard part. The easy bit is to block off the hose on the bottom of the inlet manifold:
    All I did was cut a piece of hose and jubalee clipped in a bolt like so (pic taken through the gap of the inlet mani):
    Last thing to do is to sort out the hose that runs off the left hand side of the inlet mani that runs to the break servo:
    Now the silver bit in between the 2 90 degree silicone is the 1 way valve which ensures you have servo'd brakes. The hose then just runs up to the hard pipe along the firewall. Not the hose with ASH on it but the one to the right of it:
    Now obviously I bought spanking new pipes for the brake servo bit but you can just re use most of the stuff you ripped out and the 1 way valve that was already there. The original 1 way valve was a T-piece 1 way valve so you will need to block off the bottom of the T as described earlier in this thread.
    I hope these pics and this explaination help you out, it's really not as daunting as it first seems.
    S3 Build Thread
  7. #526
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    will i need a TIP first or can i use the original also where did you get your tip from been looking at the forge tips recomend? had a look at some of the vw boys they have been making some of there catch cans out of coke cans and monster cans guess it to go with the rat look
  8. #527
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    also how much pipe did you need roughly 2m and is it all 19mm bore or 16mm bore
  9. #528
    Westy's Avatar
    Dec 2008
    17,273
    You can use the original TIP as the silicone TIPs are the same they're just made of silicone. Mine will be up for sale in the next month or 2 as I will be getting a B5 3" TIP My TIP is an Autobahn TIP from eBay:
    Silicone Induction Hose kit Audi TT 225 S3 1.8T B | eBay UK
    I had 2m of 19mm oild grade hose and I still had a lot left spare. I also recomment buying the following:
    Hose Pipe T Piece Tee 19mm 0.75 Inch Pond Fitting | eBay UK
    19mm Plastic 90 Degree Elbow Hose Joiner L | eBay UK
    19mm 3/4" Straight Plastic Barbed Connector Hose Joiner | eBay UK
    S3 Build Thread
  10. #529
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    cheers for that will get the stuff ordered probs next week just so got cash for awesome to do me cambelt next saturday.
    i may go with the different option of a yellow rockstar can as every one else has genuine oil catch cans wanna be different lol will normal samco silicone hose be ok or does it have to oil grade?
  11. #530
    Westy's Avatar
    Dec 2008
    17,273
    Get yourself 2 90 degree joiners to make sure you can bend the hose wherever you need it. It will depend on where you mount your can though.
    Oil grade hose will be better and is cheaper than silicone. It wont perish as quickly as silicone stuff.
    S3 Build Thread
  12. #531
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    will probs mount it next to the battery as i have a hks mushroom filter so got bags of room near the battery where did you get your oil grade hoses from? ive found some silcone samco pipe for 16 per meter
  13. #532
    Westy's Avatar
    Dec 2008
    17,273
    It was part of the group buy and is probably mentioned in this thread somewhere. Most auto factors should do oil grade hose.
    I might end up moving my catch can once I have a B5 tip and open filter on the car.
    S3 Build Thread
  14. #533
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
  15. #534
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    [QUOTE=Westle;1226564]You can use the original TIP as the silicone TIPs are the same they're just made of silicone. Mine will be up for sale in the next month or 2 as I will be getting a B5 3" TIP My TIP is an Autobahn TIP from eBay:
    only if it was a A3 would have had the hose off ya
  16. #535
    Westy's Avatar
    Dec 2008
    17,273
    Yeah that looks ok but not sure if the braid will restrict flexability of the hose but would lokk nice.
    Here's another option:
    19mm (ID) Oil Resistant Hose / Oil Catch tank hose | eBay UK
    S3 Build Thread
  17. #536
    S3 Nattie's Avatar
    Quattro ist für sissies
    May 2009
    Cardiff
    1,600
    Aww I see what you mean. I think il see how much I can get some 19-15mm adaptors and run a small piece of silicone between them.
    Any links of the catch can you got Dave.
    For sale
    3" Downpipe and de cat (will be going on ebay soon)
    Autogauge boost gauge
    Chrome Audi Number plate surrounds
    PM for info.
  18. #537
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    I have not got a link, i got it from a 3rd party, similar to the one you posted to be fair..
  19. #538
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Westle, did you replace your 1-way valve? I'm still running the original one with one branch tee'd off. If so where did you get it?
  20. #539
    Westy's Avatar
    Dec 2008
    17,273
    Yes I replaces mine. If you look in my pics above I have a silver 1 way valve for a boat haha
    The eBay link to the one I've got is in post #517
    S3 Build Thread
  21. #540
    S3 TAM's Avatar
    Pocket now empty
    Oct 2009
    London & Hertfordshire
    621
    I've got a Blue TIP for Sale PM...
    Revo Stage 2 with all the Gear
    BHP = 274 / Torque = 293
  22. #541
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Quote Originally Posted by S3 Baby View Post
    I have one also, autobahn one for sale.
    I got an email from the seller of the catch can I listed and its not baffled but this one is.
    AUDI A3 A4 QUATTRO TT ROUND OIL CATCH TANK SILVER on eBay (end time 16-Apr-11 12:07:07 BST)
    It looks the same as the one I linked above but a Toyosport one with some fittings and a bracket. Im going to get this one soon and spray it either matt or satin black for a OEM look.
    For sale
    PM for info.
  23. #542
    Westy's Avatar
    Dec 2008
    17,273
    That looks nice for the price mate.
    S3 Build Thread
  24. #543
    S3 Nattie's Avatar
    May 2009
    Cardiff
    1,600
    Ye, doesnt look to bad. If I when for the polished/chrome engine bay look this would go really well. I like the level gauge also.
    The inlet ports are removable so might be able to buy 19mm ports to screw in so dont have to worry about 15-19mm adaptors.
    s3dave likes this.
    For sale
    PM for info.
  25. #544
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Quote Originally Posted by darko View Post
    Anyone else want to buy one of these catch cans ? Perhaps we can do another group buy or at least save on the postage ?
    Hi yeah im up for one
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
  26. #545
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    all parts ordered just need to buy a can of monster or redbull and thats the can sorted cheers for the help westle
  27. #546
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by paul syverson View Post
    Get some pics up when you've done it mate.
    S3 Build Thread
  28. #547
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    will do probs be either this or next weekend car going for cam belt on satday but have got bank holidays to do it
  29. #548
    Westy's Avatar
    Dec 2008
    17,273
    Ok, can someone who has their can venting to atmosphere instead of back to the TIP please confirm a few things for me:
    - What size breather did you use? I'm assuming its 19mm like this one:
    Stainless Steel Breather Filter 19mm Oil/Crankcase/Air on eBay (end time 13-May-11 00:10:00 BST)
    - Where have you routed the hose with the breather?
    - Do you need to keep the hockey puck in the system when venting to atmos?
    Any pics would be greatly welcome
    S3 Build Thread
  30. #549
    Westy's Avatar
    Dec 2008
    17,273
    Ok I think i've found my answer with regards to keeping the hocky puck valve. It can go.
    All I need is some measurement confirmation before I order the alloy bung. I think the hose on the TIP to bung up is 19mm but not 100% sure.
    Also does anyone know if this will cause any issues with this breather system effectively being open and not venting back into the TIP.
    S3 Build Thread
  31. #550
    Westy's Avatar
    Dec 2008
    17,273
    Well I've ordered the parts as I got bored of waiting for a reply to my previous posts and I've found out most of the answers myself.
    Just got to figure out where I'm going to route the oil breather. Some have done it like this but I'm not sure if the fumes will stink out the cockpit:
    S3 Build Thread
  32. #551
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Hi would be nice if we could have a (how to thread) on just the fitting with pictures on this, I would like to have a go, but get lost with all the different routes for the hosing.
  33. #552
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    unsure
    What were the answers to your questions dude im curious what you found out
  34. #553
    Westy's Avatar
    Dec 2008
    17,273
    Mate I'm not being funny but I've tried to make it as simple as possible with my basic diagram and the pics I posted up the other day. It really is quite easy once you've had a look at it all under the bonnet.
    I did a bit of digging around earlier and I found out that to vent to atmosphere you can ditch the hockey puck valve and it is also 19mm. I'll be getting my parts soon so I'll put photos of that up too.
    S3 Build Thread
  35. #554
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Sticky
    Ok cool will look out for that id like to see what replaces that hokey puck thing.
    What I meant by my earlier post was a Sticky, maybe with just the pictures and a small guide, to save trawling through all these pages to find the pictures to fit it all together. Just makes it easier.
  36. #555
    Westy's Avatar
    Dec 2008
    17,273
    Quote Originally Posted by rhubarb4 View Post
    Ok mate I see what you mean. I'll try and construct a new thread from all the info already in this thread and ask for it to be a sticky. Watch this space.
    S3 Build Thread
  37. #556
    Westy's Avatar
    Dec 2008
    17,273
    S3 Build Thread
  38. #557
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Pure Genious
    Legend mate Thank you
  39. #558
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    tried this and its ****ed my car brakes are solid jumping up and down on them to try and stop any sugestions put it all back again and brakes still soild
  40. #559
    Westy's Avatar
    Dec 2008
    17,273
    Have you got the 1 way valve in the right way for the brake servo?
    S3 Build Thread
  41. #560
    Syvo's Avatar
    Jan 2011
    warrington
    1,337
    cheers m8 just changed it round and it worked
