AH FabricationsJMB Retrofits
Results 1 to 11 of 11
    Chugger
    North Devon
    2,716
    Question any of you fitted cruise control to S3
    I want it for my AMK,
    Cant get hold of a stalk off some one on here. Would just require the loom.
    Can somebody tell me if this looks like the correct loom?
    http://cgi.ebay.co.uk/Audi-TT-A3-Oct...item53de614de8
    Or even better if somebody has a loom lying around..............
    Much abliged, Jim
    57 A3 2.0 TDI Sportback (140)
    J B
    J B's Avatar
    Dec 2008
    Hants & Ox
    140
    I'm almost certain thats the right one although I dont have the part number! I had to buy the whole kit from Teeside so would imagine it to be correct!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    121 pole loom should be the right one IIRC... I bought the kit from Teeside, comes with the both looms as there is one that goes from stalk to the junction box in the scuttle and the one you have linked too from there to the ECU
    I bought this...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=370095852365
    Easy enough to fit but takes a bit of time as you have to remove loads and the ECU wiring can be a tad worrying but not too bad...
    Also need VAGCOM to code the ECU to turn on cruise control
    One of the best mods I have fitted... use it all the time
    <tuffty/>
    S3KO4's Avatar
    Aug 2009
    London
    850
    I have an after market one fitted, and I hate it... when engaged the rev behave differently, a lot slower when it comes back down. so these days I dont touch it at all.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Quote Originally Posted by tufftybloke View Post
    I agree. I got mine within 2 weeks of buying my S3. Saves quite a bit of dosh on the motorway, both in fuel and avoiding the average speed tax collecting devices...
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    <tuffty/>
    I have one in the car but not working, no fault errors. I guess it is switched off....?
    Ibiza Cupra TDI
    Gone:
    Audi C5 RS 6 - Stage 2
    Audi 8L S3 - Revo'd
    Feb 2008
    2,817
    im sure awesome gti were doing a special deal before 100 fitted.
    2000 AMK S3, Revo'd, forge 007p, B8's, H&R's, tarox g88's, ferrodo ds2500's, and in the fastest colour
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    Great mod, mine came with it, but would have been the first mod the car received if it hadn't. Great for cruising on the motorway. 70mph = 2,900revs = 35mpg!
    Chugger
    North Devon
    2,716
    sweet, iv never had cruise control but can imagine it being useful. Thats my baddest habit on the motorway, i find it so difficult to hold a constant speed.
    Hmm, looks like I would also require a 'cruise control stalkhead loom' tho. Looks like it would be no cheaper buying individually, the kit is good value for money.
    I have vagcom so not a problem there. 35mpg sounds alright!
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by finesse View Post
    Mate it is possible your brake or clutch switch aren't working correctly. have a look at this thread from when i installed my cruise control. had the same issue, turned out to be the clutch switch wasn't adjusted right.
    Ross_S4
    Aug 2009
    Dundee
    718
    Quote Originally Posted by sportstractor View Post
    You'll probably already know and have read up but...
    The difference netween the ecu looms is the type of contact terminals they have on the ecu end. there were two types in my kit and only one of them was required, the other wouldn't have fitted my ecu. just a prewarning, you should double check first.
