EM TuningBadger5
Results 1 to 8 of 8
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    Changing rear springs
    I have a 2001 S3 and had it healh checked by VAGCOM and local VAG garage. A few things have come up which is a pain but two things stand out.
    One of which is both rear springs broken at the base. According to the garage, a common fault? I am therefore looking for a "how to" replace the rear springs. I ahve heard that this a 20 minute job but would like some thoughts and opinions.
    1.) How much for OEM springs and where is best to source them?
    2.) Are there any other 3rd party rear springs that I can use instead?
    3.) Do I need specialist tools to repalce lower springs?
    Thanks for any help.
    OllieH - I think you were looking for springs late Jan. Keen to know how yours turned out.
    Rob
    Jul 2007
    Wiltshire
    210
    Chance for a Coilover upgrade ?
    Think if its just springs your after Non branded or ones of Ebay will suffice..
    http://cgi.ebay.co.uk/Coilover-Heigh...item2559121cd4
    or
    http://cgi.ebay.co.uk/PI-Audi-S3-A3-...item25582dd2d8
    Something like that.. As Far as im aware there are no specific tools aside from the C spanners needed. Axle stands or a lift thingy would be ideal to. I would strongly suggest getting a garage to do it if your not confident as i dont know what geometry or alignment will need to be carried out afterwards.
    2006-7 Audi S3- 99...Sold
    Honda CBR600RR...Sold
    2009-10 Audi S3 01...Sold
    Suzuki GSX-R 1000 + Suzuki RM-Z450.... KEEPING
    2011 Wants another S3...........
    RobW's Avatar
    Run Rob Run
    Oct 2009
    Portsmouth
    30
    roger thank you
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    Have a look at this guide to give you an idea of whats involved...
    http://noahlh.com/car/coilover_howto/
    The rears are different on the quattro (A3 or S3) to the FWD A3/Golf but principle is similar...
    Only specialist tools required for suspension are spring compressors for the front and the little spreading tool to open the front hub to remove the strut (see the above guide for details)
    Rear springs should be easy enough to remove and replace without compressing them, just need to undo the lower damper bolt (also attaches the rear ARB drop link) and push the suspension arm down enough to wiggle the spring out..
    Word of warning though.... make sure you undo the little arm attached to headlight height sensor which is connected to the passenger side upper tie bar on the rear as it WILL break if you do not before attempting to remove the rear spring...
    Depending on how low you go with the replacement springs, you may well need to get adjustable rear tie bars to dial the camber back in again.... there are a number of threads about this and look in the performance bit of the stickies at the top of this forum for more info too...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    @Huz... ??? dislike?
    <tuffty/>
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    724
    The rear ones are easy enough to remove especially when you think about why you are remoing them i.e a piece is broken so they are shorter ! But putting the new ones are pain in the neck - that's all I know when we attempted the job on the ground floor using just axle stands and a jack and no spring compressors (well at tleast the mini ones).
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    A3 1.8t Quattro Sport!
    May 2011
    suffolk
    278
    jack the car up both sides put on axle stands..
    put the jackunder rear beam..
    undo both lower shock bolts..
    lower jack a bit and the springs will fall out
    new ones in, jack beam back up and put shock bolts back in
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,444
    Quote Originally Posted by ja3mie View Post
    ...as long as you don't have a quattro which the OP does ...
    <tuffty/>
