AH FabricationsJMB Retrofits
Results 1 to 22 of 22
Thread: Dropped door:
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Dropped door:
    Has anyone elses a3/s3's door dropped?.
    Mine sit slightly lower than they should now (9 years old )
    Is it just a case of jacking them back up with a block under, or would i need to remove the wing and adjust the hinges?
    If they are able to be jacked up, do i need to remove the lower door moulding?
    cheers
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    I did a search a while ago and found a thread where the jack technique was mentioned.
    Dunno if any special treatment is required! I haven't tried it yet.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    Feb 2007
    enfield
    64
    please dont jack up your door ( you will damage it !!!!!!) there are special tools needed to ajust it.
    amd remap,brembo 4 pots,k&n,powerflex mount
    JS1500's Avatar
    Howdy
    Sep 2009
    1,167
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Oh, whats the special tool? Is it likely my local bodyshop will have one?
    Cheers for the link JS.. Ive already had to replace both door locks, but the door is nearly 10mm too low.
    Oct 2007
    Plymouth
    203
    Check the pics towards the bottom of the link, there is a hinge you can adjust with a torx behind the wheel arch plastic
    http://www.audi-sport.net/vb/showthr...o-adjust-doors
    Mar 2010
    UK, SOUTH
    19
    yeah dont jack the door, best to just adjust the hinges. be easy enough to get too and remember wen adjusting it go a little higher than the desired level as door will drop slighty under its weight.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    I had a look at the door today, i think my window frame may need adjusting, as the door is all inline.. Just the top part of the frame is lower.
    Maybe it will even cure my wind noise!!!
    AudiiduA's Avatar
    Midlands
    358
    On my old capri's it was caused by worn Pins!
    Chugger
    North Devon
    2,716
    Quote Originally Posted by AudiiduA View Post
    LOL,, its because those pins are crafted from phildelphia.
    Seems crap that the door has dropped overtime, this is surely not common!
    57 A3 2.0 TDI Sportback (140)
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Apparently it is. Due to the weight etc, Ill report back once its repaired...hopefully with pics!
    Mar 2010
    UK, SOUTH
    19
    frame is easily adjusted, jus need the door trim off and there's adjusters for in and out and up and down. had to do mine as some numpty hadn't aligned it properly and it had wind noise.
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Was it a one man job?... or did it require assistance.
    Think i must have misaligned it when i fitted my new lock.. DOH!
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    Hi mate,
    Weirdly enough both my doors seem to have this problem, it was only after I read this thread that I went out to look. I get mega whistling noise above 50mph.
    The common thing is age, mine is also 9 years old. I am having my front bumper off tomorrow to do some bits, I will email you pics of the air con control unit refurb once I get it done tomorrow.
    Good luck.
    2001 A3 1.9tdi 130pd (Aka "Osama Bin Diesel") 130bhp 310NM = PMSL
    Done:
    EGR switched off using vag.com. Full no expenses spared service. Refurb Gearbox, new clutch/flywheel.
    In the works:
    Mk II TT Steering wheel (No Airbag), vag.com switchable 3 stage map. Big brake kit. Hybrid turbo.
    L1 HCS's Avatar
    Candy Tetris Champion, Mahjong Champion, Magic Ball Champion
    Oct 2006
    cymru
    4,597
    My doors have dropped too, I have to pull the door real hard before it latches on, it feels like my windows are about to shatter! thankfully it's being sorted. But imagine if they were so bad that they fell off during your travels on the motorway! that would be terrifying! (but funny at the same time as long as it didn't smash into any living thing). lol
    "Swallow your pride occasionally, it's not fattening." - Frank Tyger
    "Avoid making irrevocable decisions while tired or hungry." - Robert Heinlein
    9099's Avatar
    TDi? Liberties!
    Apr 2009
    London
    122
    Dunno about funny mate! lol
    One thing is for sure if your doors do fall off on motorway the person the car behind might need some fresh undies. lol
    Done:
    In the works:
    L1 HCS's Avatar
    Oct 2006
    cymru
    4,597
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Well, tried this today.. lifted the window frame up inside the door...
    Stopped the wind noise, but now it squeaks on the seals!!!
    argh, more fine tweeking needed..
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Does anyone have a copy of ELSA, with the procedure for re-aligning the door frame?.
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    Quote Originally Posted by csweatherston View Post
    Hi Callum, I have the Audi workshop manual ELSA-WIN system on CD/DVD-ROM if you want a copy ping me next week and Ill bring over with your haldex spanner for you
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    That would be ideal if you could mate, i ordered a copy from ebay but it never showed up
    Are you heading out this way next week?
    Sep 2009
    741
    PM inbound buddy
