Chris NottSky Insurance
Results 1 to 15 of 15
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,080
    2002 S3 airbox removal, how??
    OK so while trying to remove the top half of my airbox to check the paper filter last night, I was completely beaten by it!
    I know it is purely because I don't know where all the screws/clips are and once I have done it, it will be second nature second time around. I also want to remove it fully from the MAF to use a spray engine cleaner (thanks MikeGTR!).
    Can someone point me to a guide/type it up quickly?
    Much appreciated!
    James
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    Undo the two screws that si behined the aribox, they secure the top half to the top, then unclip the maf, unscrew the jubilee clip holding the tip on to the maf, pull the tip off the airbox and there you go, airbox lid off.
    JD09's Avatar
    Dec 2009
    3,080
    Ah great, thanks. It looked like the airbox was stuck from the front of the engine, thought there must have been clips that I was missing! Got the screws off, but just wouldn't budge!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,233
    It takes some working to get the tip out od the way etc, alos theres a 10mm bolt holding the base of the airbox down just past the screw on the right handside.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    There's also a plastic hose thing you need to disconnect near the battery, you need to squeeze the plastic hard and pull, might need a few attempts to get it off if you've not done it before.
    JD09's Avatar
    Dec 2009
    3,080
    Appreciate that JoJo, thanks!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,519
    Quote Originally Posted by JD09 View Post
    Thinking about it, it might be part of the lower half of the airbox, might not need to remove the part I mentioned to get the top off, youy will see when you have a look.
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    Did MikeGTR say you need to spray that stuff post MAF? not pre MAF. You might want to check
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    JD09's Avatar
    Dec 2009
    3,080
    I will need to remove all of the airbox as I want to use a spray cleaner as well, so your advice was helpful fella.
    Cheers.
    JD09's Avatar
    Dec 2009
    3,080
    Quote Originally Posted by Cookstein View Post
    Yeah after the MAF, i.e. without the MAF attached? You've got me thinking now. . .
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    yeah, though he did. So you need to remove the MAF from the TIP as well
    Alex S3 AMK
    JD09's Avatar
    Dec 2009
    3,080
    OK. I may get a mechanic mate of mine just to stand by with it lol. Means he can control the throttle as I spray as well!
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Dude its really not tricky
    I'd undo the jubilee clip holding the MAF to the TIP
    Unplug the MAF
    Disconnect the plugs from the back of the airbox
    Unclip the rubber hose from the bottom left of the airbox
    Undo the 10mm bolt at the back right of the airbox (onto the suspension turret)
    Undo the 10mm bolt from the front right of the airbox (opposite corner to the above one)
    Lift the airbox out, sliding it to the left slightly due to the airfeed going into the wing.
    Then its just a case of undoing the screws that hold the lid down. The lid almost has to open like a hinge, its a lot easier with the airbox off the car.
    Unscrew the 2 phillips screws holding the MAF to the airbox and you're away!.
    Thats how I would do it on my A3, cant see the S3 being that much different
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    and make sure nothing gets sucked into the TIP whilst your spraying that gunge in there
    Alex S3 AMK
    JD09's Avatar
    Dec 2009
    3,080
    Will do, Cookstein
