EM TuningBadger5
    feville's Avatar
    Frank
    63
    What are the signs of a weak actuator?
    Hi guys just want to confirm that my actuator is on its way out...
    Car boost hits 12psi then rises to 14psi even though its been mapped and should be holding 18psi ish
    Is the norm for the boost to peak to say 21psi then drop and hold 18psi?
    R-Tech remap - Forge 007p - Forge carbonio - Janspeed catback - N75h - Coilovers - TT comp rims - Powerflex bushes - EBC stoppers
    Chugger
    North Devon
    2,716
    get it on vagcom the look at command boost vs actual (block 115)
    there is usually a spike, its the time it takes the ecu/boost controller to gain control of boost i think
    you want to elimate boost leaks etc first
    57 A3 2.0 TDI Sportback (140)
    feville's Avatar
    Frank
    63
    I'd need to register my Vagcom to do that wouldnt i as i'm currently using the freeware version?
    feville's Avatar
    Frank
    63
    Anyone had any experience in one going on them?
    feville's Avatar
    Frank
    63
    Anyone? I'm running an AGU so cant measure command boost vs actual (block 115)
