JMB RetrofitsAH Fabrications
Results 1 to 14 of 14
    tim-igoe's Avatar
    Cheshire
    25
    HELP NEEDED QUICKLY!!!
    Made a thread not so long ago about my revs sticking. Cut a long story short i found out that it was the throttle body that needed cleaning. Ive had some time on my hands today and cleaned it, however i did read something about it needing resetting into place.
    Can someone please tell me how to do it, By the way i dont have Vag Com
    Thanks in advance
    Tim
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    disconnect the battery for a bit. once reconnected, turn the key onto ignition, stand by the TB and wait for it to stop making a noise. then turn the car over.
    it has worked for me on both Audis i have ever owned. my car runs perfectly now without stalling since i cleaned the TB out.
    Now to many mods to list! Lots of power, torque and Leather!
    tim-igoe's Avatar
    Cheshire
    25
    thanks alot mate, will do that now.
    tim-igoe's Avatar
    Cheshire
    25
    right ive done that but now its extremely juddery and has a wine thats constantly there... Is this normal??
    tim-igoe's Avatar
    Cheshire
    25
    Anyone???
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Apparently, disconnecting the battery doesn't work, see link: http://www.seatcupra.net/forums/show...throttle+align
    Your better off seeing if anyone local has VCDS and can do a Throttle Body Alignment for you using the right tool.
    Imteyaz.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    what you mean juddery? revs up and down?
    did you take off the TB to clean it or just clean the bit you can see? there will be lots of crap behind it.
    How long did you leave battery off for?
    if you have half cleaned it it could be worse than before (talking from experience) if the tb is not closing properly because you have not cleaned it fully, it will not be closed properly, and therefore run like shat.
    I would leave it running for a bit so the ECU can work out whats going on. This method has never failed me. Of corse people will want you to think it dont work. thats how people make money out of you. Audi ECU`s learn and adjust do they not?
    i will defend this till im blue in the face!! lol its ALWAYS worked on both my Audis, shown to me by other ASN members also! Im sure no 1 will defend me tho in the True ASN way!
    tim-igoe's Avatar
    Cheshire
    25
    the car sound like it is about to stall. or a sort of misfire. should i just let it run. its more of the wine that sounds like its causing damage.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    dunno what the wine is mate, can you get a vid of it? what else have you done to the car?
    Did you take the TB off to cleen it or do it on the car?
    tim-igoe's Avatar
    Cheshire
    25
    erm.. i took the whole thing off to clean it and im certain that everything has been put back on properly, maybe its just another problem. I will just let it run probably tomorrow when i have time and hope it sorts itself out
    Thanks alot mate, much appreciated.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    no problem. just be sure there is no grub left on the edge of the throttle plate. thats all it took on one of my attempts years ago as it was not closing properly and was sticking.
    shiney shiney FTW
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by ALPINE View Post
    shiney shiney FTW
    Blury Blury FTW
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    When I had my remap my idle used to be up and down so Midland said to clean the throttle body out. I didnt even take it off the car, just popped the hose off, held it open and sprayed in a load of carb cleaner. Out poured a shed load of filthy black gunk so I repeated it a few more times till it was clear.
    I had no problems with mine after that although mine has a throttle cable on it if that matters?. It took a few seconds to work itself out and was back to normal, no realignment issues here?
    My money is on something else but you really need to vagcom it to get a specific answer or you'll be fault finding for weeks.
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by Lemon S3 View Post
    Blury Blury FTW
    lmao!! i knew someone would say somthing!! cams no good for close ups!
    here have a non fuzzled one!
