Chris NottEM Tuning
    Dec 2009
    12
    51 plate A3 Drivers door card removal
    Hi all, need a bit of help here, window stopped working so need to remove door card, found one fixing under grab handle but can`t seem to find any more, is there only the one and then card pulls off or are there some more hidden ones, dont want to bugger door card up, nothing on google for 8L, only later models and not the same.
    beachbuggy's Avatar
    Surrey
    1,727
    Under the grab handle, there is one screw which holds a plastic cover. remove this and you will find 2 bolts/screws which need to be removed. Then there are 2 some screws one at the top of the door panel in the hinge area and the other at the other end of the door by the lock. Once these 4 screws/bolts are removed the the whole door card will lift up and out but be careful of all the wires as they aren't that long.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,672
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
