Chris NottMonster Motorsport
    Oct 2009
    150
    Engine code help
    Just plugged my car into vag and it's came up with 17704 unknown error. The car is running fine and temperature is usually around 60 but has crept to 90 at times. The car has been remapped and seems to be drinking fuel. Can anyone please give me an idea as to what this may be?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Sounds like the common coolant temp sensor/thermostat issue...
    http://wiki.ross-tech.com/index.php/17704/P1296/004758
    The reason the car is heavy on fuel is because the ECU still thinks its in cold start and making the mixture richer... as the CTS can't tell the ECU the engine is warm enough either due to the CTS being faulty or the stat stuck open then the ECU won't know when to stop enriching the mixture.
    There are loads of threads here if you plan to do it yourself else the parts are around 30 from GSF or any other motor factor plus a couple of hours labour and a bit of G12 coolant to top up the system.
    <tuffty/>
    Oct 2009
    150
    Cheers, thanks for the help
    Oct 2009
    150
    Right I've purchased the cts and the thermostat. Can anybody tell me roughly where they are? Sorry for all the hassle
