JMB RetrofitsChris Nott
Results 1 to 8 of 8
    Sep 2009
    50
    Cylinder head bolt (img incl)
    Hi,
    i'm in the process of changing my head gasket but i have came to the cylinder head bolts and cant find the right socket to remove them.
    i have a set of new bolts so i have took a picture to see if anyone can help with the fitting
    (p.s. its not a a torx 50 or a gleeb(?) took the bolt to 3 car shops and they couldnt find the correct fitting)
    any replys thanked in advance
    http://img.photobucket.com/albums/v3...5022010038.jpg
    http://img.photobucket.com/albums/v3...5022010036.jpg
    Audi A3 97' 1.6 Midnight Blue | Standard as of yet |
    Ross_S4
    Aug 2009
    Dundee
    718
    Alright mate,not sure of the size but I am sure that needs a bit called a RIBE bit.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,460
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,477
    That you linked too is for 16v bolts... 20v heads are a tad different mate... not much but enough... doing some work of a 1.8t engined Mk2 Golf and the engine was built using 16v head bolts rather than 20v head bolts...
    IIRC... M10 is for 20v and M9/10 is for the slight;y smaller 16v bolts...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,477
    ....found some pics...
    RIBE tool (16v)
    Polydrive tool (20v)
    <tuffty/>
    Sep 2009
    50
    Thanks for all the replies, however my car is only the 1.6 8v... is it likely to still just be a m9/10 16v?
    Sep 2010
    12
    Quote Originally Posted by lugz View Post
    Hi,
    i'm in the process of changing my head gasket but i have came to the cylinder head bolt set and cant find the right socket to remove them.
    My uncle is also replacing his blown head gasket the other day when he encounter the cylinder head bolt and he is also having trouble which socket to remove them. Lucky I was able to find this thread with so many links of the right tool to do the job. Anyway, I'm gonna let my uncle find this Ribe tool so he could already finished the job on his head gasket. Thanks for this thread. It was really helpful.
