Volks AutosMonster Motorsport
Results 1 to 23 of 23
    1an
    23
    Few questions about new s3 ive purchased
    hi there, from what i understand i cant run a dumpvalve on the 1.8t due to the ecu etc and a recirculater needs to be used. but awesome gti supply a forge splitter valve, will this still give the desired noise or is it best to stick with a forge recirculater?
    cheers ian
    Sep 2009
    Essex
    2,366
    a "scooby" or a "pretza" would ahve given the "desired" sound. they come with baseball caps as standard too
    im sure youtube would show you show a forge splitter sounds though. brap
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Most people on here stick with the Forge re-circ (007p) valve. I'm not sure how the Split-R sounds tbh, but some folk mount their 007p upside down for increased noise...
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    1an
    23
    ok thats what i seem to have been reading that sticking with the forge recirc is a favoured part to fit etc, was jsut looking into different parts that are avalaible as ive read the original part is liable to failure etc.
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    The ecu will still work but you will be using too much fuel for the air supplied. Just get a forge or bailey recirc valve and you will still get quite a loud noise.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    1an
    23
    Quote Originally Posted by Lemon S3 View Post
    tbh im looking for whats best for the car dont wanna ruin it etc, just the searxch on here isnt great etc, obviously noise isnt everytihng but it is a by product of fitting these parts?
    JS1500's Avatar
    Howdy
    Sep 2009
    1,167
    I think what's generally considered best for the car is either a Forge 007p or Bailey (DV30?) re-circ valve.
    The original Bosch unit is prone to failure (it's plastic), especially if the car has been re-mapped. A broken original can mean that your turbo may suffer damage (i'm not very technical so i'll let someone else give you the details or correct me) so it's wise to upgrade.
    Going from the standard Bosch to a Forge 007p the sound is more noticeable but certainly not loud or chavvy.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    You'll still get a bit of noise if running an aftermarket air filter or drilled air box with a 007P. The SplitR valve isn't a very good bit of kit to be honest. It is a jack of both options (recirc and atmospheric), but a master of neither. I would steer clear myself.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by JS1500 View Post
    A broken standard DV has a diaphragm inside, instead of a piston. The diaphragm has a quicker response time, but is prone to splitting once been used for a while. If it splits, you basically have a massive boost leak all the time.... which isn't the best. Not sure it would cause any long lasting damage to the turbo to be honest, but obviously would affect performance vastly.
    The 007P has a spring and piston - they don't split. When serviced regularly, they are as good as gold for countless miles of driving.
    You can grab one at DPM Performance. See here: http://www.dpmperformance.co.uk/forg...996-p-887.html. You might even get forum discount if you ask nicely.... lol.
    Homer Simpson
    Sep 2009
    Essex
    2,366
    my s4 has two oem plastic bosch DVs. at 115k miles ONE was dead.
    i put a pair of new N710s on. 23 each. a forge one is 80+
    therefore, if a bosch fails (and theyll last c.115k) i can replace four before im out of pocket
    so unless you are running loads of extra boost, dont get the forge unless you just have a burning desire to do whatever everyone else does
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Matt82 View Post
    Whilst I agree with you in principle, the Bosch ones don't just fail. They tend to split over a period of time, getting progressively worse as time goes on. When you say one was dead at 115K that's not bad at all - but do you really know how long it had been 'going' for? Could of been adversely affecting the engine since 80K for example and you didn't notice.
    Not everyone's experiences are as good as yours - I have heard of them failing much earlier than that. Spending the 80 or whatever in my opinion is worth it, because you eliminate a well known and common potential cause of failure. OK, they're more expensive, but you KNOW that it will be working in 100K time.
    And it's shiny!
    That's my thoughts anyway.
    Homer Simpson
    chris432626's Avatar
    S3 Upminster
    Oct 2009
    Upminster, UK
    33
    Is this something you can fit yourself?
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Yes, very easy to fit.....
    Homer Simpson
    vetch's Avatar
    S3
    Apr 2009
    412
    Ive never really looked into it, but I thought everyone changed to the uprated piston type DV because it gave some sort of performance benefit? But it would seem the diaphragm type standard DV is more responsive?
    My remapped S3 has a standard DV on it and is boosting fine. I had been planning to change to the 007p for a while, but i dont think I'll bother now, I'll probably just a stick a new standard one on the car and save myself some money.
    Audi S3
    Sep 2009
    Essex
    2,366
    i fitted one to a mates AGU. she still had compressor surge afterwards. it was then pulled apart and greased, it just did nt respond properly
    the OE bosch ones are the same as on the 993 and 996 (i think) turbo, they can obviously take a fair bit of boost
    23 each. i dont think there is any comparison
    s3gav's Avatar
    Jul 2009
    414
    i have a forge split-r dv
    rubbish dont bother with them, im getting a 007p instead
    SOLD 2002 S3,full black heated leather, bose, 997 turbo's, lcr splitter, coilovers, superchip, blueflame cat back, k&n, forge dv, forge hoses, forge quickshift, forge rear tie bars and forge fmic
    Surrey
    57
    Just to put my boot in it.. i have a DV30.. don't notice any change in responsiveness but the noise is immense. im 19 so i'm allowed to be that little bit immature :P just always have liked the sounds that they make so when i got 1 at 1/3 the rrp i couldn't resist
    Sep 2009
    worcester
    1,097
    i got a dv30 and i cant hear the bloody thing, maybe with the windows down i can just about hear it, or with windows up and stereo off
    i have got std airbox/filter not drilled though so thats more than likely why
    1an
    23
    sounds like im gonna take a trip to AMD and purchase a 007p today then as they are local to me.
    cheers for the info guys, just want to make sure everytihng is in order before i look to remap the s3.
    JS1500's Avatar
    Howdy
    Sep 2009
    1,167
    You can get the 007p from Awesome for about 15 less than RRP, if you don't mind it having 'AWESOME' engraved on it!
    That's what I did anyway.
    They also sell the standard one.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by jonny87 View Post
    Swiss cheese it......
    Homer Simpson
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    I've got a drilled spare if you want to try it out....?
    Homer Simpson
    devan's Avatar
    Jun 2010
    117
    Is this 'drilling the airbox' as simple as it sounds lol.
    Just drilling lots of 6mm??? holes in the bottom of the airbox?
    My S3 has one 6mm hole in the bottom, is this standard?
    Cheers.
