Volks AutosSky Insurance
Results 1 to 28 of 28
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Mud like coolent
    Coolent light came on this morning so topped it up with some antifreeze, just poped out 2 see if it's all ok, opened it up to have a look and it's gone to a mud like texture, brown in colour. Never seen this before what should I do
    thanks mike
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    May 2006
    Surrey
    175
    Blown headgasket or cracked head mate. Its gone like that because it has mixed with your engine oil.
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
    Sep 2009
    Essex
    2,366
    what was it like before you put the antifreeze in?
    if you mix the wrong antifreezes ive seen it go muddy before
    drain and replace. and you hve to get the stat out to flush the block and we all know that getting the stat off a 20vt is totally totally impossible!!!111123
    Sep 2009
    Essex
    2,366
    Quote Originally Posted by ben_turbo1 View Post
    jesus christ. i thought my answer was a bit dramatic but i think you definately take the biscuit
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Quote Originally Posted by Matt82 View Post
    No it was fine before I put the new antifreeze in, got 2 drive it back home 30miles in a bit then I'll drain flush and refill it, cars been running fine and temp is normal. Hopefully a clean out will sort it out then
    Now : Cupra R 225
    Sep 2009
    Essex
    2,366
    what anti freeze did you add and what was in it before?
    mixing the wrong stuff turns antifreeze to sludge
    youll want to back flush the rad, block, everything
    personally id clean it and fill it with water. run the car for a couple days and start again till it runs clear then put the normal G12 in it.
    Quote Originally Posted by indiemike View Post
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    I second the above, thats exactly what I would do as well.
    Homer Simpson
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    I put some ready mixed halfords stuff which I know I shouldn't have done in the 1st place but thought it might be ok, the stuff already in there I'm not sure what it is. I've checked my oil and seems fine and just poked a pen into the coole t to see if was mud like all the way through but it seems to of just caused a layer on the top underneath is water like and is a bron colour, mate was saying if oil was in it then the colour would be whiteish
    what's the best way to clean the system out
    Now : Cupra R 225
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    did you mix g11 and g12?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Sep 2009
    Essex
    2,366
    that would do it.
    g11 shouldnt be in a 20vt lump tho
    Sep 2009
    Essex
    2,366
    get the hoses off the rad and use the bottom pipe to back flush it
    stat out and flush the block
    fresh water in. run it for a few days and do it again. you could even put some biological washing powder in to disperse any grease thats in there if you really fancy it
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,506
    You need some of the pink stuff, either actual G12 Plus or an equiv OAT compatable antifreeze.
    As stated flush it and get that crud out and all good
    Sep 2009
    Essex
    2,366
    i think they actually renamed it again to G12++Plus
    lots of pluses
    its slightly purple now, but it apparently mixes with anything. its a right slut
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    This is the stuff i used this morning http://www.halfords.com/webapp/wcs/s...Id_229902#dtab
    Ive ended up dropping the audi at my parents and lent my dads rover, lol its like a boat on wheels but the seats aint half cunfy
    Now : Cupra R 225
    Sep 2009
    worcester
    1,097
    flushed my system using dishwasher tablets
    i now offically have the cleanest tubes in britain lol
    drain that cr*p out your sytem refill with water, crush up two tablets and pour into header tank, go for a 10 min drive, drain and repeat as many times it takes untill it looks like you have got it all out, easy peasy mate
    Sep 2009
    Essex
    2,366
    sounds mental but jonny isnt joking, works a treat. you dont want the crap pluging the little channels through the rad
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Absolutely agree with the above.
    Audi S3's live longer with Calgon.
    (it even works with the tune....)
    Homer Simpson
    Sep 2009
    Essex
    2,366
    the petrol fumes are doing you in son
    Sep 2009
    worcester
    1,097
    hes spent too much time in that garage surrounded by heads, bent rods, busted blocks etc
    i think he was a bit suspect before but now i think the best thing would be section the poor fella
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    On the Q & A for the product....
    'Can I use this to top up G12 coolant in my 05 Golf GTI? '
    Halfords Ready Mixed Top Up Antifreeze is the most suitable product from our range with which to top up your 2005 VW Golf being that it is an OAT based coolant similar to that recommended by the manufacturer.
    Similar? WTF is similar? The answer they were looking for was 'No, you should use G12+ or G12++, but use this because we don't care and just want to sell it to you for a million quid......'
    Retards.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by jonny87 View Post
    Sign me up doc....
    Free lodgings and food? Yes please.... Better than being a working citizen in this country at the moment.
    Homer Simpson
    Sep 2009
    Essex
    2,366
    well i think his thread is such a breath of fresh air on a forum where half the members wont even know if their car has an engine or not
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Whats an engine?
    Homer Simpson
    Sep 2009
    worcester
    1,097
    Sign me up doc....
    actually that does sound good doesnt it?!!
    good thread to read, wouldnt want to be on welly's side of the computer though, more than likely i would of had a minor heart attack by now with all the ups and downs lol
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    It has been a bit like that. One minute it was a quick and easy head removal. Then the block swap. Then the second head removal and refit.
    Still, as my sig says..... Never take life too seriously.... Noone gets out alive anyway!
    To be honest mate, I've had help from a couple of good mates, we've had a laugh, smoked probably a thousand cigarettes, and boogied and made stupid lyrics to songs. All in all, a good crack really.
    All in all, hard work, disappointing at times, but not all bad!
    Homer Simpson
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Funny enough i came across it before, pulled some handle in the car and it just appeared out of thin air
    I know i shouldnt of used the ****ty halfords stuff but that was all that was around, was 4am and needed to get 2 work but lesson learnt not to but **** in the car as it will result in **** happening, just never heard of it going into a mud like mixture
    Now : Cupra R 225
  28. #27
    Sep 2009
    Essex
    2,366
    ah its a risk, unless you knew it was going to sludge, what can you do... there are quite a few different types, some cause more of a mess than others.
    this could be a good time to get a new expansion tank. they make engine bays look great, even im tart enough to have bought a new one before. 9 from VW
  29. #28
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,436
    Too funny man dude!
