EM TuningMonster Motorsport
Results 1 to 8 of 8
    SteveBAM's Avatar
    Black '03 S3
    Sep 2009
    A, A
    180
    another BT question..??
    I've been doing some research lately on a BT upgrade for my S3, and i read somewhere that a GT2871r would work fine on a stock chipped motor...
    is that true?
    i am asking because I'm thinking of going with that turbo, and because i will be taking my transmission off for a needed clutch upgrade(its slipping) i thought i might as well install the turbo with the manifold at the same time and run the car like that till i get to upgrading my internals.. i know it will be risky and i will have to avoid high boost and power while doing this, but i am very curious in finding out if the car will work fine???
    thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    erm no... you heard wrong mate.... soz... A GT2871r isn't a bolt on mod in any respect...
    <tuffty/>
    SteveBAM's Avatar
    Black '03 S3
    Sep 2009
    A, A
    180
    no i don't mean bolt on, but with a manifold and remap...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    To fit a GT2871r you would need mani (top mount or under slung), custom DP, custom TIP, larger injectors, inline fuel pump, rods and would need custom mapping (stage 3).
    BT can be done on a budget (I know, I've done it) but there are things you cannot skimp on as they are required to make the engine run right. You can get away with some stuff as I have but as I have found out, going BT does require a little bit of work...
    <tuffty/>
    Sep 2009
    worcester
    1,097
    if i were you mate id save the money so you can do it all in one foul swoop
    not just turbo/manifold, its all the supporting mods that MUST go with it
    no point doing a bt upgrade half heartedly as it will bite you in the ass
    SteveBAM's Avatar
    Black '03 S3
    Sep 2009
    A, A
    180
    ok i understand what you guys are saying and i know that its not the right way to go. i was just thinking if something like this would work so i could avoid taking apart my engine twice.. and by saying that i meant installing a gt2871r with a manifold, DP, exhaust and just keeping my current remap-intercooler-injectors and ect. and running at low boost. i know that would be very risky but i was just wondering if anyone had tried it..
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    tufty ive had a read throught your build thread,
    if i was to go for something on the same lines as you have gt30 etc and everything that is needed what sort of price would it cost? plus full labor costs as im a rookie.
    quite interested in getting it done around may as im out the country at the mo.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Quote Originally Posted by dannycawsey View Post
    Best bet is to drop Bill at Badger 5 a PM (http://www.audi-sport.net/vb/member.php?4263-badger5) and he will give you the low down... I can't really remember how much I have spent as I have bought bits as I went along...
    Certainly cheaper if you are spannering yourself but difficult as there is quite a bit of fabrication involved which would mean Bill needs the car at his place to do the work...
    <tuffty/>
