Volks AutosSky Insurance
    Aberdeen
    24
    Urgent help required with fault diagnostic codes please
    hi thanks for looking, I took my S3 to garage today as the dreaded engine light came on
    they did a diagnostic check and the following codes appeared
    P1296 - FAULT IN COOLING SYSTEM (level of coolant has not changed)
    if that isnt bad enough a second code also appeared
    P0011 - camshaft retardation (1) target value not attained
    the invoice also reads additional info m31585 i dont know if this is part of the fault or not, any help would be greatly appreciated as even the mechanic does not know where to start.
    Can anyone recommend a good mechanic or garage in Aberdeen.
    Thanks.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    What tool did they use as those codes and descriptions are a little odd... searching through VAGCOM wiki revealed the following...
    P1296:
    http://wiki.ross-tech.com/index.php/17704/P1296/004758
    ...and
    P0011
    http://wiki.ross-tech.com/index.php/16395/P0011/000017
    First one suggests the temp sensor and or thermostat is causing probs... does the temp gauge read ok or does it read below 90?
    Second looks like a fault in the VVT system...
    <tuffty/>
    Aberdeen
    24
    hi the garage uses a bosch system sorry should have noted that.
    i havent noticed anything with the temp guage but i have only had the car for a week
    and have nothing to compare it with but it was at 90 on 200 mile journey home and the light came on during a short journey.
    big regrets as i have no comeback private sale i wish i listened to the wife and bought from a garage.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    The stat and temp sensor is a common problem and not a major expense with parts not costing much above 30.... the VVT (if thats what the prob is) maybe more expensive if it needs replacing... looking at the description on VAGCOM wiki it may be a case of just cleaning the part... not taken the VVT off/apart before so can't be much more help there unfortunately...
    <tuffty/>
