dyce martin
hi thanks for looking, I took my S3 to garage today as the dreaded engine light came on
they did a diagnostic check and the following codes appeared
P1296 - FAULT IN COOLING SYSTEM (level of coolant has not changed)
if that isnt bad enough a second code also appeared
P0011 - camshaft retardation (1) target value not attained
the invoice also reads additional info m31585 i dont know if this is part of the fault or not, any help would be greatly appreciated as even the mechanic does not know where to start.
Can anyone recommend a good mechanic or garage in Aberdeen.
Thanks.
Thanks.
