Sky InsuranceChris Nott
Results 1 to 8 of 8
Thread: No Boost
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    No Boost
    Right ive just spent the last 4 hours fitting a forge TIP and a forge D,V relocation,
    but there is a sensor that goes into the N75 which now will not reach,
    drove it home from work which is 600 meters with out this sensor connected and there was hardly any boost.
    Im guessing this is due to the sensor not being connected?
    What does the sensor do?
    can i just cut it and add some cable to it?
    cheers Danny
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    By sensor I assume you meant the N75 wiring plug???
    If you do then it kinda needs that to work hence no boost...
    <tuffty/>
    Terrier QTS's Avatar
    Jan 2007
    Leek, Staffordshire
    42
    The N75 controls the Wastegate, so you're going to need it connected.
    2001 A3 TQS - Custom Code Phase 1 - Silicone TIP- Supersport Springs, Shocks and Top Mounts - Powerflexed front end - HIDs - 18" TTV6's **FOR SALE**
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    ok cheers for that guys will get some hose tomorrow and move the N75 so i can connect the wiring plug.
    Aug 2009
    Gosport, Hants
    367
    Do you mean the electrical connection that goes onto the N75? The ecu uses the N75 valve to control how much pressure is seen on the actuator, which in turn controls the wastegate of the exhaust turbine. With the connection removed, the N75 will not be working, so full pressure will be seen on the actuator, meaning the wastegate will open alot earlier than normal, hence your not getting any boost. Wastegates without any ecu control are typically set up to open at half the original boost level, incase of N75 failure, which is what yours is doing now.
    Personally I would not cut and extend the electrical connection, but maybe extend the TIP connection by adding a length of silicon pipe to it, bringing the N75 closer to the electrical connection.
    HTH
    2003 Dolphin Grey S3, with a few mods....
    Jul 2007
    Wiltshire
    210
    Have you tried.
    2006-7 Audi S3- 99...Sold
    Honda CBR600RR...Sold
    2009-10 Audi S3 01...Sold
    Suzuki GSX-R 1000 + Suzuki RM-Z450.... KEEPING
    2011 Wants another S3...........
    Cawsey
    Dec 2009
    Valencia, Spain
    481
    reconnected the n75 today and ate a boost bar now shes running fine again..
    Sep 2009
    worcester
    1,097
    Quote Originally Posted by dannycawsey View Post
    oooo you eat the boost bar, i was jamming mine in the turbine housing
