Results 1 to 13 of 13
    Oct 2004
    Stratford-upon-Avon
    40
    S3 Slipping Clutch in 5 gear while cornering fast
    While accelerating in 5 gear tonight while some guy in an RX8 was trying to race me round fast country bends my revs run quickly from 4K to around 5K rpm. Relaxing the throttle brought it back into line. I have tried booting it in second gear to see if the clutch slipped again but it appeared OK. The car is one day out of warranty - DOH!
    Anyone experienced the same or know what was happening?
    PS RX8's may as well not bother
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    Re: S3 Slipping Clutch in 5 gear while cornering fast
    good kill
    do you wreckon could be the ESP kicking in? i haven't got it to yet but apparently it plays with clutch
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    good kill
    Oct 2004
    Stratford-upon-Avon
    40
    I didn't see the ESP light flash
    Mar 2004
    Liverpool
    140
    [ QUOTE ]
    [/ QUOTE ]
    I SHOULD FEKKIN HOPE NOT!!!!! lol [img]/ubbthreads/images/graemlins/lol.gif[/img]
    Drivin through lanes that quick my eyes are glued firmly on the road!!!
    RX8 killer!!!...respect man!!! [img]/ubbthreads/images/graemlins/beerchug.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2004
    Stratford-upon-Avon
    40
    Who recons Listers will replace my clutch 1 day after the warranty expires! I knew I should have extended it for 495!
    Oct 2004
    Stratford-upon-Avon
    40
    [ QUOTE ]
    dummi said:
    good kill
    [/ QUOTE ]
    Can anyone confirm that the ESP can play with the clutch?
    DavidR's Avatar
    Scotland
    1,295
    [ QUOTE ]
    dcallaghan said:
    [Can anyone confirm that the ESP can play with the clutch?
    [/ QUOTE ]
    It has absolutely nothing to do with the clutch.
    DavidR's Avatar
    Scotland
    1,295
    You'd be stuffed anyhow, the clutch is seldom covered under manufacturer or aftermarket warranty - wear and tear item.
    dummi's Avatar
    smoking a6
    Mar 2004
    brumingham
    1,188
    my bad
    Drill's Avatar
    Land of Good Beer, and better Roads :-p
    928
    ESP will use the brakes and (IIRC) cut the throttle in some circumstances. If the wheels slipped a little, I could see "Maybe" the increased revs, but most of the time that would kick off the ESP light [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/crazy.gif[/img]
    That was absolutely NO HELP, was it? [img]/ubbthreads/images/graemlins/angel.gif[/img]
    [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Oct 2004
    If you where driving hard for a while, then it was probably because the clutch got hot, like when your brakes get hot, they fade. The clutch is opposite and can slip when hot (clutches slip most in higher gears)
    Otherwise its just warn out and needs replacing!
    Nov 2003
    Central Scotland
    253
    Your clutch it fcuked. Buy a new one. nothing to do with ESP. Nothing to do with clutch heating up unless you had just done a dozen 1/4mile back to back.
    Stevie
