Chris NottJMB Retrofits
Results 1 to 9 of 9
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    4WD System...........agen
    Right... I've replaced the complete back end of the car which came off a mk4 golf and only done 14,000 miles. Still got to bleed the brakes, may have fecked the master cylinder as I didn't know about not to push the pedal down all the way until after I finished the rear.
    Anyway this thread is mainly about the 4wd, its on axle stands, started it up, put it in gear but the bloody rear wheels still aren't working. First time I forgot to connect the wiring plug on the back of the diff, plugged it in but still no joy. Am I missing something here??
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    738
    Some people have mention an earth strap causing Haldex not to work, prob worth checking its not been missed.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    have you checked the fues ain't blown for the haldex system?
    Sep 2009
    West london
    379
    I fault the back wheels only spin when the front lose traction that's what the hadlex for
    Chugger
    North Devon
    2,716
    try slowing one of the wheels down, then see if it kicks in
    Feb 2008
    529
    yer there was a thread on here a while ago, and im certain people came to the conclusion that the rear wouldnt spin when the cars on axle stands
    Audi A4 Avant 1.9TDI Quattro Sport 2004
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Quote Originally Posted by sportquattro View Post
    When I removed the old diff etc I didn't notice an earth strap nor on the new one.
    PS3: Broady_11
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Just had a thought while watching lee evans that when I forgot to connect the wiring plug on the back of the diff first time I started the car, when I plugged it back in I didn't turn the ignition off completely, so thought it may have needed to be turned off to reset itself or something. Started it up a minute ago and..............................it WWOOOOOOORRRRRRRRRRRKKKKKKKKKKSSSSSSSSSS!!!
    I have 4 wheel drive again I can also confirm that it will work on axle stands.
    Just need to sort the blooming brakes out now. Does anyone know the correct order to do it in, I've found a number of ways. Is it MC, Proportioning valve, RR, RL, FR, FL or RR, RL, FR, FL, MC?
    PS3: Broady_11
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    if all 4 wheels are off the floor then they should all spin 100%
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
