Volks AutosChris Nott
Results 1 to 9 of 9
    Petrol & temp gauge
    Hi guys,
    first time I have used this and sick of Audi over priced labour charges.
    Anyway My 2001 A3t quattro has a liitle problem. The fuel and temp sensor show more than it should be. The trip computer reads correct to the amoumt of fuel. When I fill up max the fuel gauge shows more than a full tank and the temp use to go no higher than 90 but even if turned on from cold it reads 1/4 warm....... has anyone seen this problem?
    Help .................
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    its good that it shows no higher than 90!! as for the other probs, im not sure. Fuel sender maybe?
    Now to many mods to list! Lots of power, torque and Leather!
    Sorry .... it now shows over 90 ....
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    with your temperature, it might just be the dial, seeing as though your fuel dial is also dodgy then maybe it is just your temp dial. And if its reading quater warm from a cold start then its more than likely to be the dial, because its imposibble for it to be that warm from a cold start. Unless youve got a radioactive rock in there!
    But it could be your thermostat sticking closed, in which case the coolant wouldn't reach the radiator. How hot is it reading when fully up to temperature?
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Could be the temp sender for the erratic temp display, as for the fuel display maybe the fuel sender. Have you had it on vag com?
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    I had this problem on my 1999 A3 1.8t sport. It was 2 wires worn through and touching..
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,092
    Get the car on VAGCOM if you can mate, that will tell you what the issues are.
    To me it sounds like the temp and fuel sender are shot, your best bet is to get them replaced, however, as already mentioned, see if you can get the car on Vagcom 1st, it will save you a lot of time and money if you can get the diagnostic right instead of playing a guessing game.
    Whereabouts are you, as im sure there will be someone local that will be able to get your car on VAGCOM
    mark_sarah's Avatar
    Limp mode!
    Norwich
    203
    Vagcom did not pick my fault up at all. As it was a brake in the circuit rather than a faulty part.
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Quote Originally Posted by mark_sarah View Post
    Could you elaborate on how you fixed it? Which two wires were they? Behind the clocks?
    I've got the exact same problem with my temperature gauge. Whilst the car's clocks are completely off, it's at the bottom of the temp gauge and as soon as I turn the car on it goes a quarter of the way up the gauge, and so it sits at a quarter over the gauge when it's warmed up. I know the temperature's all fine and the temp sender and thermostat have been replaced, and I've had mine on VAG-COM and it's all ok, it's definitely the gauge but I'd love to know how to fix it.
    I've also found this guide for fixing the TT cluster, but it's the same problem I think and have read others have used this guide to fix their faulty petrol and temp gauges, but I don't know if I'd like to open my clocks up.
    '02 A3 TDI quattro sport
    8L IS DE BEST
