JMB RetrofitsChris Nott
    14
    Leaking screenwash bottle / qucik fix?
    Hi all, my front headlight screenwash pump thingy leaks which in turn drains the whole screenwash bottle.
    I don't really care about headlight washers, all i need is the main screen wahser to work (as i understand it would fail the MOT in that state).
    My question is; is there a quick fix or a way to by-pass/disconnect the headlight wahser so only the main screenwash jets are working?
    Thanks.
    P.s: my A/C smells a bit like a damp dog on a wet day, think i need to change the cabin filter, where is that located ?
    MIKE GTR's Avatar
    WICKFORD, ESSEX
    366
    Just put a jubilee clip around the pipe before it gets to the pump, tighten it until no water can pass
    I'm not normally a praying man, but if you're up there, save me Superman
